Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
    Problem Solver:
  • 11 Answers
Log into the router and go to the configuration page for your WAN port. Change the connection type to static ip.
Posted on May 01, 2008
Won't dhcp connect with router
the Di-604 is the router. it will provide DHCP if the DHCP function is turned on. IT will not get its own IP from another dhcp router though. At least I have never gotten any to. I set the router IP address manually and then I set the DHCP range to be something that wont interfere with any other static IP addresses.
For instance. I set the router to instead of its default of Then I set the range of DHCP to to
You have to log into the router to do these changes. Your manual will tell you how to do this and what the default IP address is that you will need to type into your browser.
Mar 09, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
Cant connect the d-link website after ip replacement.
Have you tried to reset your router? If not, do so. It will reset everything to factory default.
To reset, look for a hole near the ports, where it says RESET. Use a pointed object such as a paper clip.
Hope it helps.
Aug 24, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Cannot share connection
The IP address that you have is an automatic IP address the Windows generates. It basically means your computer is not getting an IP address from the router (DHCP). You should try powering everything off. Then, in this order, power on your modem, wait 30 seconds, then, power on your router, wait 30 seconds, then power on your computers...This should fix the problem since one computer is working already.
Mar 22, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
D-link DI-604
I didn't quite understand what you meant but Ill explain some stuff you to that might help.
From what I understand you have a dial up router/modem, which is external (outside of your computer/seperate), and you hookup your phone line to it, which then connects into your DI-604 WAN port.
WAN Static IP settings are related to the settings given by the ISP that stay constant. There are 2 types of IP, static and dynamic. I think dial up is dynamic, since you have to connect/disconnect through the phone when you want to get on, this causes the ip to change at each reconnect, unless your ISP treats it differently.
I have no idea what you want to get out of the WAN static IP settings, but this should be handled by the dialup router/modem it self, and generally you dont have to manually enter the static ip, unless the ISP requires it, in that case you would enter this stuff there. The ISP Gateway Address refers to the ISP's router address/modem, I think, since I never heard the term before.
After "My problem:", I didn't understand your problem and can't give you further info until you clarify. Also if you internet is fully connected and working, and you still have problems then you could try resetting the router, by holding the reset button for 10 seconds. This will erase all settings. If that doesn't help try unplugging the router, then holding the reset button for 5-10 seconds, then plugging it in at the same time, then it should be fully reset, unless I forgot how it was supposed to be reset. ( I used to have the same router)
Feb 27, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I am trying to connect my D-Link router to my PC. I changed providers from DSL to CAble, and now it doesn't work. When I try to hook up the router to the cable modem, I no longer have internet service....
First, you have to directly attach to the cable modem whichever computer the instal tech used to establish your account. Make sure that connection works. Then re-insert the router and clone the MAC address of the instal computer to the router. Then check your DHCP settings. Make sure it's set to get a new IP from your new provider. You may then have to then release your IP and resubscribe.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
How to enable WAN IP in a DI-604 Router for 3 computers
"I wanna make the 2nd pc a server but it isn't accessible through the WAN ip. "
Well that explains everything. If you want to get to from the internet, you need to tell the router where to send packets. You do this by going to the ADVANCED section and configuring Virtual Servers. For example: If you are setting up the computer at 102 as a ftp server, ftp uses port 21. The name would be FTP, private IP would be, Protocol is TCP, and the Private and Public ports would normally both be 21. Don't forget to Enable the rule.
What this does is tell the router that when ever a request comes in on port 21, it should forward it to To access the external side of the router you need to go to (according to the image you posted)
Jan 03, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Wan indicator does not light up..
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Please remember that D-Link AirPlus G wireless devices are pre-configured to connect together, right out of the box, with their default settings.For a typical wireless setup at home (as shown above), please do the following:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4) If you are connecting a desktop computer to your network, install the D-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCI slot on your desktop computer. You may also install the DWL-G520, or the DWL-520. (See the printed Quick Installation Guide included with the network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6) Install the D-Link DFE-530TX+ adapter into a desktop computer. The four Ethernet LAN ports of the DI-524 are Auto MDI/MDIX and will work with both Straight-Through and Cross-Over cable. (See the printed Quick Installation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
-Open the web browser
-Type in the IP Address of
the Router (
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
The Home>Wizard screen will appear. Please refer to the Quick Installation Guide for more information regarding the Setup Wizard.
Home > Wizard
These buttons appear on most of the configuration screens in this section. Please click on the appropriate button at the bottom of each screen after you have made a configuration change.
Home > Wireless
SSID- Service Set Identifier (SSID) is the name designated for a specific wireless local area network (WLAN). The SSID’s factory default setting is default. The SSID can be easily changed to connect to an existing wireless network or to establish a new wireless network.
Channel- 6 is the default channel. All devices on the network must share the same channel. (Note: The wireless adapters will automatically scan and match the wireless setting.)
WEP- Wired Equivalent Privacy (WEP) is a wireless security protocol for Wireless Local Area Networks (WLAN). WEP provides security by encrypting the data that is sent over the WLAN. Select Enabled or Disabled. Disabled is the default setting. (Note: If you enable encryption on the DI-524 make sure to also enable encryption on all the wireless clients or wireless connection will not be established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Host Name- The Host Name is optional but may be required by some ISPs. The default host name is the device name of the Router and may be changed.
MAC Address- The default MAC Address is set to the WAN’s physical interface MAC address on the Broadband Router. It is not recommended that you change the default MAC address unless required by your ISP.
Clone MAC Address- The default MAC address is set to the WAN’s physical interface MAC address on the Broadband Router. You can use the “Clone MAC Address” button to copy the MAC address of the Ethernet Card installed by your ISP and replace the WAN MAC address with the MAC address of the router. It is not recommended that you change the default MAC address unless required by your ISP.
Home > WAN > Static IP Address
Static IP Address- IP Address-
Subnet Mask- ISP
Gateway Address- Primary
DNS Address- Secondary
DNS Address- Choose Static IP Address if all WAN IP information is provided to you by your ISP. You will need to enter in the IP address, subnet mask, gateway address, and DNS address(es) provided to you by your ISP. Each IP address entered in the fields must be in the appropriate IP form, which are four octets separated by a dot (x.x.x.x). The Router will not accept the IP address if it is not in this format.
IP Address- Input the public IP Address provided by your ISP.
Subnet Mask- Input your Subnet mask. (All devices in the network must have the same subnet mask.)
ISP Gateway Address- Input the public IP address of the ISP to which you are connecting.
Primary DNS Address- Input the primary DNS (Domain Name Server) IP address provided by your ISP.
Secondary DNS Address- This is optional.
Home > WAN > PPPoE
*** Please be sure to remove any existing PPPoE client software installed on your computers.
Choose PPPoE (Point to Point Protocol over Ethernet) if your ISP uses a PPPoE connection. Your ISP will provide you with a username and password. This option is typically used for DSL services. Select Dynamic PPPoE to obtain an IP address automatically for your PPPoE connection. Select Static PPPoE to use a static IP address for your PPPoeE connection.
PPPoE- Choose this option if your ISP uses PPPoE. (Most DSL users will select this option.)
Dynamic PPPoE- receive an IP Address automatically from your ISP.
Static PPPoE-you have an assigned (static) IP Address.
User Name- Your PPPoE username provided by your ISP.
Retype Password- Re-enter the PPPoE password
Service Name- Enter the Service Name provided by your ISP (optional).
IP Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Primary DNS Address- Primary DNS IP address provided by our ISP
Secondary DNS Address- This option is only available for Static PPPoE. Enter the static IP Address for the PPPoE connection.
Maximum Idle Time- Enter a maximum idle time during which Internet connection is maintained during inactivity. To diable this feature, enable Autoreconnect.
MTU- Maximum Transmission Unit-1492 is the default setting-you may need to change the MTU for optimal performance with your specific ISP.
Auto-reconnect- If enabled, the DI-524 will automatically connect to your ISP after your system is restarted or if the PPPoE connection is dropped.
Home > LAN
LAN is short for Local Area Network. This is considered your internal network. These are the IP settings of the LAN interface for the DI-524. These settings may be referred to as Private settings. You may change the LAN IP address if needed. The LAN IP address is private to your internal network and cannot be seen on the Internet.
IP Address- The IP address of the LAN interface. The default IP address is:
Subnet Mask- The subnet mask of the LAN interface. The default subnet mask is
Local Domain- This field is optional. Enter in the local domain name.
Home > DHCP
DHCP stands for Dynamic Host Control Protocol. The DI-524 has a built-in DHCP server.
The DHCP Server will automatically assign an IP address to the computers on the LAN/
private network. Be sure to set your computers to be DHCP clients by setting their TCP/
IP settings to “Obtain an IP Address Automatically.” When you turn your computers on,
they will automatically load the proper TCP/IP settings provided by the DI-524. The
DHCP Server will automatically allocate an unused IP address from the IP address pool
to the requesting computer. You must specify the starting and ending address of the IP
address pool.
DHCP Server- Select Enabled or Disabled. The default setting is Enabled.
IP Address- The starting IP address for the DHCP server’s IP assignment
IP Address- The ending IP address for the DHCP server’s IP assignment
Lease Time- The length of time for the IP lease. Enter the Lease time. The
default setting is one hour
Advanced > Virtual Server
If you would like to view more of this manual CLICK HERE
Thank you for using FixYa. Have a nice day and please remember to give this solution a good rating.
Jun 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Internet problem connection.....
your computer has been set up to be the PPPoE account holder for the modem. if you have a router, you will need to configure the router to login to the ISP account using the PPPoE information so that your router is the account holder for the modem, then you will be able attach multiple computers to the internet using the router.
Jun 21, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D-link di-604
I have no success disabling the DHCP server. For me at lease, this will not work
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
D Link 604 will not connect to internet
Hi Goldy,
The 604 should setup easily. Make sure you have it set to automatically get IP if you are using Cable, and for PPPOE if you are using DSL.
Once you have it setup. Shut down everything. Plug in the modem, wait 2 min. This allows the modem to get the info it needs from your ISP. Then bootup the 604. Wait 2 min, for it to get the info it needs from the modem, then boot up your computers.
Got to start>run and type in CMD. In the black box that opens, type in IPCONFIG. Your IP listed should be 192.168.x.x. THe X's can be any number from 1 to 253. If the IP is, you are not getting data from the 604. Check your firewalls, expecially if you are using a third party one, like Norton.
Jan 06, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
933 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
