SOURCE: O2 XDA Keep on Restarting
I have the same problem with mine, I sent it for repairs, and after paying about 300 dollars , it comes back with not change at all. I ll send it back again and see how it goes. Sorry coudnt help you more.
- Ked.
SOURCE: My O2 XDA II mini restarts continuously
If you remove the back case on the right hand side just above a small red plug there is a kill switch that looks like a small black lever, use a small amount of blue tack to jam it upwards. When its held in position your phone should work fine after that.
i used to have a 02 XDA II , i know if you end up using all the physical memory it will restart to clear it , are you aware of how much memory is being used ?
also when it restarts does it then reinstall all the applications again ?
