some discs don't work in some recorders. I always use verbatim, ritek or tdk discs and have very few problems. if the recorder suddenly dislikes a batch of one brand, I'll use one of the others.
If the disc that you bought is a bluray disc it will not play on a standard DVD player. But if you ended up with the regular one it should work unless there is a glitch in the disc, if that is the case return the disc.
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get
a lens cleaner and use it to clean the lens, but if the lens still does
the same thing even after using the lens cleaner, then it means you
would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
You may need dvd- disks instead! ( it usually one or the other!) and if your player does take a DVD+ you might have to change brands of disks ( I know this sounds stupid but all disks are not created equal! and do not work in all players!
Please rate this response and help keep this site free!
THANK YOU!
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
If the region setting is correct and won't even read a cleaning disc, there's not much you can do. Either the DVD drive or the Main board (aka MPEG board) is faulty and will have to get it repaired. I'm not sure about UK, but in Australia, Bush manufacturing warranty period for DVD players is 12 months.
