Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
Projection Televisions Logo
Problem with the Projection Televisions
Crt coolant change on a rear projection tv
By stupid824 on Apr 02, 2008
color cloudy out of focus
  1. I want to try and change the coolant on my Philips/Magnavox rear projection TV. How much coolant do I need to purchase? Where can I purchase it. About how much does it cost? What tools will I need?
  1. i have had a tv tech out to look at my philips magnavox projection tv. he said that the blue and green coolant needs to be changed. Is this something that we can do ourselves? He wants $450 to do it. And where can i get the coolant?
Best Solution (1 of 6)
posted 2 years ago
  • Rank: Apprentice
  • Rating: 89%, 14 Votes
I suggest doing 1 tube at a time so you won't have to do a major re-convergence adjustment. Remove the green crt first. remove the high voltage lead from the splitter, then the yoke and convergence plugs then the ground wires going from the crt ground strap to the crt board.Lay the assembly down with the drain plug facing up( you will have to support the crt neck with a block of wood)I use a turkey baster with a plastic straw taped to the end. Remove the drain plug and suck out the coolant and empty into a plastic container.I use an old milk carton. When most of the coolant is removed remove the lens assembly. Then remove the half moon shaped plastic from the reservoir . suck out the remaining cooland and use a paper towel to sop up the remaining debris. Reinstall the half moon and lens. Fill the reservoir allowing a litle room for expansion.Reinstall the tube then do the customer convergence adjustment. Do the blue tube the same way. good luck
Was this helpful?
Yes
No
6 people thought this was helpful
Add a comment
Solution 2
posted 2 years ago
  • Rank: Guru Televisions & Video
  • Rating: 88%, 472 Votes
I find it most productive to remove effective tubes, lights, from the unit. Unplug ground wires, cables,(yoke/conv yoke) & crt socket. Drain fluid, via plug, take chamber apart, clean & disinfect. if this a phillips or mag you will probally only need to do the blue& green tubes. for more detatailed info respond. CAUTION THIS IS NOT WATER; it is: Ethylene Glycol. A coolant like anti freeze in your auto. Remove so wont spill on pc boards. Good luck.
Was this helpful?
Yes
No
Add a comment
Solution 3
posted 12 months ago
  • Rank: Apprentice
  • Rating: 100%, 8 Votes
Here is a detailed step by step guide with pictures
http://www.riddledtv.com/repair/journal/CRTCoolant/
Was this helpful?
Yes
No
8 people thought this was helpful
Add a comment
Solution 4
posted 1 year ago
  • Rank: Apprentice
  • Rating: 95%, 10 Votes
You can do it yourself. You can get the coolant from mcmelectronics.com they are 6.99 apiece and you need three bottles to change all three but the red may not need it. I did all three anyway. After reading many post on this site I found it easier to remove each crt form the tv and do the change in my garage. I couldn't see risking spilling the coolant all over the circuit boards. You can find post on site on how to do it. Couple things though I couldn't find that I found easier. I pulled the drain plug and poured coolant into a coffee can then removed the lens and expansion valve. No need for a turkey baster. Also the drain plug only turns one way. Do not force it or will break off one side and then your going to have to replace it or rig it somehow. I did have to rig one by putting a small screw it the side that broke. It did work like a champ but I wouldn't recommend it. Remove the crt one at a time then put them back. Tag each wire on where it goes . The red wires that on connect to triple bridge/ flyback (going to each crt) looks like there is a disconnect they just need to be pulled straight up fairly hard. There is two rings around the end the show you how far they go back in. They just push back in place. it does looks like you may have pulled the connection off but it does reconnect. They circuit boards push straight down from the tubes and only the grounds should need to be disconnected, The green crt does have a few more connects. I also pulled the screen off, You need a wide blade putty knife to remove the trim then there are just screws. It took about 4 hrs although most of it was just firguring out how to remove everything once I did one crt the others took twenty minutes start to finish.
Was this helpful?
Yes
No
Add a comment
Solution 5
posted 1 year ago
  • Rank: Apprentice
  • Rating: 83%, 6 Votes
[url]http://www.tv-forums.com/forum/TV_Equipment_C4/Projection_TV_Forum_F24/How_to_-__crt_coolant_change_and_advanced_convergence_P50090/[/url]
I documented the procedure I did on the link above. For convergence issues try this link:
[url]http://www.tv-forums.com/forum/TV_Equipment_C4/Projection_TV_Forum_F24/Philips_55p916_convergence_issues_P50073/[/url]
Was this helpful?
Yes
No
2 people thought this was helpful
Add a comment
  1. CRT coolant change and advanced convergence - how to
    I documented the procedure I did on a Philips 55" rear projection 55p916
    http://tinyurl.com/lmp6eu CRT coolant change procedure
    http://tinyurl.com/l7bd7r basic and advanced convergence
    Reply
Solution 6
posted 2 years ago
  • Rank: Apprentice
  • Rating: 75%, 5 Votes
my tv tech examined my mitsibishi 65 inch rear projection tv and said it would be cost effective to fix because coolant had leaked onto the pc board is there a way to fix it?
Was this helpful?
Yes
No
Add a comment
Solve Your Projection Televisions Problem Now!
Click here to get instant support from our best Experts
Please type the numbers below to complete your post:
Can't read it? Try a different one.
Type the numbers here:
Solve this problem
Bold
Italic
Underline
Insert List
Insert List
Video
Pictures
Insert Link
Links
Share your knowledge with the Fixya community today!
Popular Solutions for Projection Televisions
replaced bulb on sony KDF-42WE655,
replaced bulb on sony KDF-42WE655, When power turns on then turns off with 3 flashs of red light continuouis?
picture is multiple color or
picture is multiple color or double piture
the words and pictures on my tv are outlined in
the words and pictures on my tv are outlined in red i tried the convergence thing but the bars wont line up
POWER COMES ON BUT GOES TO STANDBY AND TV WON'T
POWER COMES ON BUT GOES TO STANDBY AND TV WON'T COME ON. WAS TOLD IT WAS A FAULTY FLYBACK (DON'T KNOW WHERE IT IS ...
when you turn the tv on it go right back off
when you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the ...
Unsolved Problems rss
When I press the power
When I press the power button on the remote and on the front of the tv the green light on the front panel lights up, you ...
lines going across the screen
50vf820 green hitachi...green tint to the hole
50vf820 green hitachi...green tint to the hole screen.
M61WH185 rca scenium front panel flashes 5 times
M61WH185 rca scenium front panel flashes 5 times and no picture
No picture red light in front just blinks
Solve this problem:
Bold
Italic
Underline
Video
Pictures
Insert Link
Links
What is this?
Get an Expert to Solve your Problem:
Top Projection... Experts
Rank: Guru
Rating: 91%, 6509 solutions
Rank: Guru
Rating: 87%, 2072 solutions
Rank: Guru
Rating: 90%, 6170 solutions
Get an Expert to Solve your Projection Televisions Problem
Get Immediate Assistance!
Let our Experts solve your problem!
More than 2 million solutions and counting...
