Question about Toshiba 43A10 43" Rear Projection Television
43A10 43in I have a split in the screen that is distorting the whole aspect of the picture. I would like to know where to buy a replacement and is it an easy fix ? Thank you David davidjbarrington@btinternet.com
  • Debarro Apr 02, 2008
    Its the outer layer that has split/cracked, I take it I gain access though the back and replace layer that is affected leaving others untouched ?
    Thanks
  • 298 Answers
Yes, the screen can be replaced. The screen is comprised of 3 screens. The Fresnal Screen (inner screen), Lenticular Screen (middle screen), and the Protective Screen (outer screen). Please see below for links to these items.
Need all 3 to complete screen assembly.The only screen that is still available is the innermost screen, which is probably not the 1 you need. You will only be able to find the middle (lenticular) and outer (protective) screens from a distributor that has them in stock as no one will be able to order them from the manufacturer.
  1. Fresnal Screen
  2. Lenticular Screen (no longer available)
  3. Protective Screen (no longer available)
Posted on Apr 02, 2008
    New Friend:
Thank you
43A10 43, I am david
Posted on May 05, 2015
I have a toshiba 43A10. its start fine but 5 minutes later the picture doubles red blue. i try to fix but can't what is the problem?
Posted on Aug 10, 2010
  • 927 Answers
If the plastic screen is split? yes it very easy to replace. The best place to purchase such items is your manufacture. You will get the best price and they will deliver to you home. CAUTION there is more than one screens on your tv, make sure what layers are affected.
My picture fills the whole screen to the point people look distorted
Look on your TV remote. Look for a button that reads "Aspect". While watching TV push the Aspect button until the picture is they way you want it.
Sep 01, 2014 | Samsung La32d400 32" Hd Lcd Wide Screen Tv...
About 3 yrs old. Picture is distorted for about 1/2 hour until tv warms up. Now has horizontal lines going through the picture and stays distorted on the right side of the screen.
This tv problems it is alway the board that call the T-CON decodering board it is dying.This T-CON decodering board sit in the middle at the bottom of the tv LCD screen panel.This T-CON decodering board decodes all the tv picture dots pixels before it go into the tv LCD screen panel itself.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish T-CON decodering board for the replacement.
May 09, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
I need to buy a replacement for my Vizio vu42l
If you still have it I would be willing to buy it whole or all the boards on it
Sep 22, 2009 | Vizio GV42L 42 in. LCD Television
Horizonal- picture is wavy
i have the same problem.  i know it involves changing the Aspect.  there is an Aspect button on the remote which does not work for me, but could for you?  also, after pressing the menu button, some options come onto the screen and i used to be able to get to Aspect that way also, and now i can't.  i hope you can!  if not, do we need a manual for it?  good luck.
Sep 09, 2008 | Olevia LT32HVM 32 in. LCD Television
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
HDTV
It is obvous that the aspect ratio that you are watching the program in is the native mode if you see the proportions correctly. If the native mode was in 16:9, it would not stretch when you change to this mode.
The broadcaster may be down converting all their video to 4:3 because the majority of sets in his area are still on the old aspect ratio.
Jerry G.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Toshiba 43A10 43" Rear Projection Television Logo
373 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
