DVD/CD receiver DVT312
I can"t get any cds ordvd to play. I have power, I push for tray to open, it opens, I insort cd and i don"t get any video or spound
    Problem Solver:
  • 7 Answers
PLEASE USE LENS CLEANER TO CLEAN AND TRY AGAIN.
Posted on Apr 02, 2008
SOURCE:
I have a panasonic sa ak15 stereo system, the five cd trays have cds in them, i pressed the cd open button but cds don`t come out, the system screen says change, what could be the problem?
The door loader motor isn't working. Sometimes the plastic tray warps and hangs a bit. Mine still hangs, but I can give it a push to close. If you can see the door trying to open you can help it open but you have to be quick or you have to press the open button more that once.
Feb 24, 2015 | Panasonic Audio Players & Recorders
How do i playcd on my computor
1. Switch on your computer according to the manual. Make sure your headphones are plugged in, or your speakers are plugged in and powered on.
Open the CD or DVD drive tray. Do this by pressing the button next to it.Insert CD into the drive, then close the drive tray by pressing lightly on the front of the tray.
Launch a music player. Open Windows Media Player, iTunes, or any other program that will play CDs, then press play
Aug 19, 2014 | Microsoft Windows Vista Ultimate Edition
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
Audio /video dvd/cd don't play on my system. Open tray keeps opening. Or if dvd/cd sticks in it just keeps reading...and then says cannot play...plshelp. System is 2 years old
turn on the player with the case openned, pay attention to the optic. No problem with the Optic if red light flashes. Replace your motor dynamo player with new one
Jun 22, 2010 | Audio Players & Recorders
CD is stuck in my bose lifestyle system, the message displays as "opening" but does not open
Not familiar with this model but all cd tray's have a manual release mechanism, its usually a small hole on the front of the tray. I've found a paper clip unwound usually works fine. Push it in the small hole, you will feel it stop against something, push a little harder and the tray should open enough for you to manually pull it open.
Jan 24, 2009 | Audio Players & Recorders
I have a jvc ux-g50 micro compenent system. Radio plays but will not open cd holders to play cds. Displays number (162)can you please help?
I have a jvc ux -g5. All of a sudden when i turn it on the cd tray no 1 ejects by itself and not closes when i push the button. From time to time it dispalys error 162. Addionaly not any cd fuction is corresponded. Any idea for solving the problem?
Dec 04, 2008 | Audio Players & Recorders
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Disc tray does not come out
as techman said "the old" carry with cds inside problem" yes you most have one cd inside thats the problem but letme tell you something is a problem for a cualify tech becouse to remove that cd you have to brake apart the hold cds carrier...good luck
Aug 02, 2006 | Onkyo DR-C500 Multi-disc DVD Player
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Ekse
