Question about HP Pavilion dv6000z Notebook
Cpu or motherboard
I have a dv6135nr HP pavillion laptop. one company says it has a bad cpu the other says it has a bad mother board. How can I tell? I have another laptop but I like the set up of the HP better.
  • Rajkumar Bordoloi
    Rajkumar Bordoloi May 11, 2010
    will you plz give the full specs of your labtop
  • 520 Answers
Components like diodes,capacitors and transistors are the only parts on motherboard you may have probs with and these are around the power input .the other issue is if the input connector becomes loose due to wear n these cases no lights or noises will be seen or the case of the cpu;lights will be visable and various noises but nothing on screen.this doesnt always mean bad cpu could also be graphics board or invertor(for nothing on screen)
Posted on Apr 06, 2008
  • 236 Answers
Laptops are not the same as desktop PC that you can easily swap parts to be able to determine which one is causing problem. i suggest that you refer to your product manufacturer service to determine which is causing trouble if other companies are giving you different opinions
Posted on Apr 02, 2008
Hannstar j 94v-0 mv-6
Hi Maurizio,
Here is an Ebay link for a replacement Mother Board.
Hope this helps!
Please rate and Thank You!
Aug 27, 2013 | HP Pavilion dv6000z Notebook
My hp pavillion 503n has a amber light in front...power supply fan comes on but doesnt power up
This could still be a power supply issue. You can buy a power supply tester. This will tell you if the power supply is putting out power to all of the cables.
The other cause of this issue could be a motherboard issue. HP would have to replace the motherboard. A lot of the time HP make their mother boards to fit only their cases. This makes it hard to place a non HP board into a HP case.
Feb 08, 2013 | Computers & Internet
Power cord loose at the insertion point in the laptop. Jack coming loose from the mother board. Can I bypass the jack and run power directly to the battery? Can i take laptop apart and solder the jack back...
Yes, you can take the laptop apart and resolder the jack to the motherboard. I've never done it, but have read articles about it and watched a video on youtube about it. Go here and you will find a fast video about it, which will give you an idea about what you have to do (it's a fast motion video). There will be other videos to refer to, also. I couldn't find one for the xz148, specifically, but there are some for the Pavillion series. Sounds like you've identified the problem, the task now is to get it apart to get at the power jack solder points. Take pictures as you take it apart, to help you with any problems reassembling it. Good luck!
Apr 22, 2010 | HP Computers & Internet
Blank Screen on start. No display
You need to replace the motherboard. When nothing comes on the display this means the bios on the motherboard is bad and the board and cpu need replaced.
Mar 17, 2010 | HP Pavilion dv2000t Notebook
My hp pavillion dv000 wont trun on, when i press p[ower buttin , lights comes on, no fan noise, dvd drive make litlle noise, green light on and off, after20 seconds alllights trun off, please help
mother board repair or replace disc check and bios is still coming up but the part that kicks on fans for cpu isnt working hope fully it didnt damage cpu but its possible
Nov 07, 2009 | HP Computers & Internet
I want you to try first swap the power supply box  of the PC if no change ?
go to the CPU socket remove the CPU check if any component is burnt that area if ok put a new CPU  then on it .
If still behaving the same ,then the mother board is bad get a new mother board
Good luck
Oct 01, 2009 | Foxconn P9657AA-8EKRS2H (6938279104065)...
My laptop does not turn on
No idea why they fixed the problem then said it is the motherboard. There are times though when the motherboard is actually bad and it does need to be replaced even with replacing the jack. With a motherboard it has to convernt electricity and sometimes the wiring is fried or bad. But if it works then let it run, if not, I would take it some where else and have another company check to make sure that they did not melt the board causing it to be a board problem
Feb 20, 2009 | HP Pavilion ze4300 Notebook
HP will not cover the repair if guaranty is expired.
Video card on your laptop is integrated on motherboard, and the repairman must replace the whole motherboard to fix it.
I quote : "Only half the screen works the rest is justa grey colouring." that is more likely a problem with the ribbon cable, connecting LCD, or with LCD screen itself, in some case , as said by the repairman , it can be the video card.
if the repairman did not open and inspected the laptop LCD display , connector and cables, then the problem it is probably the ribbon cable or the LCD panel.
The technician mentioned the motherboard, because that is the most expensive repair service, so that he can cover his back.
Ask a quote to a different technician, see if this can give you different quotes for all possible faults.
The possibilities are:
1 Replace ribbon cable
2 Replace LCD display
3 Replace motherboard.
Oct 14, 2008 | HP Pavillion dv9740us Notebook
Cpu fan is turning but thr is no display
Your motherboard is probably dead. Send it in to a technician
Jul 23, 2008 | HP (D7580-60003) Motherboard
PC not booting
the mother board can have a short and the green light is on, replace the motherboard. when the power box goes bad, most of the time it shorts the mother board out, this has happened to me a few times. Farren
Dec 25, 2007 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
