Question about Intel D845GVSR Motherboard
Motherboards' video card slot was damaged,
Hi hello! The video card slot on my motherboard was damaged, and the solution given to me by the technician in our area, said i should replaced the motherboard of my pc, which i find too expensive. And I was thinking that is it possible that I get to replace the video card slot since below the motherboards slots there are 4 or less than three slots on my motherboard.Can i use one of these slots since its empty. Please help me out on this problem. Thank you very much for the time evryone spend on reading my problem. I will appreciate everyones suggestion. Thanks..
  • Intel Master
  • 13,434 Answers
If you don't use your pc for gameing, assumeing the motherboard still works!
you could buy a PCI video card
http://www.si87.com/Products/Videocards/agpvspci/agp-or-pci-or-isa.jpg
Here is a example card you could buy
http://cgi.ebay.com/NEW-ATI-Radeon-64MB-DDR-Dual-Head-VGA-PCI-Video-Card_W0QQitemZ230237362135QQihZ013QQcategoryZ3762QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Before you buy, make sure the motherboard works! becouse if the motherboard is too damaged it wont work at all and you would waste your money on a pci card.
Posted on Apr 02, 2008
  • Ekse Apr 02, 2008
    if the motherboard doesnt work you have to buy a new one.
    If you need more asistance, let me know. Good luck.
SOURCE:
Sir my motherboard is on contineu but not show display
Hi Good day.. before we troubleshoot the display of your unit, let me ask you some questions? what happen to the unit before it was broke? i need information to fix your problem easily and fast..
Suspicious problem:
RAM- Not properly seated to the slot..
Video Card- video card maybe damage.
Capacitor in board- have been blown up.. (over voltage)
Aug 29, 2012 | ASUS P4GE-MX Motherboard
Hello,i have 601-686A motherboard(yes it's old) at country side and pretty sure that i'm using on board video card now(8 mb),anyways was wondering if it supports a radeon 9250?On System specs it...
Does your old AGP card got three "cuts" in her fitting board ? If yes your Radeon 9250 must have same fitting shape too. Otherwise voltage is different and cannot be installed. (Dont try again cause you may damage both card and motherboard).
If the fitting on both cards is the same then your new card maybe damaged or incompatible.
Jul 18, 2011 | Intel Motherboard
Hi Is there a PCI Express slot on the motherboard MSI K9VGM-V I see 2 PCI slots and another white slot above is this for a PCI Video card THANKS
On your MSI K9VGM-V, you do have a PCI-Express x16 slot, which is used for most video cards now days. You can see the full slot diagram on the picture below.
The one for the video card is labeled: PCI Express x16 Slot
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | MSI K9VGM-V Motherboard
How to install Geforce 8800 GTX video card to my computer.
Hello ,
Just fix the card in the pci slot given in the motherboard , and then connect the monitor to that card. Then after getting into the windows use the driver cd to install the given driver fot the card and restart your system. To find the pci slot : It must be nearly from down the second or the first one.
Oct 21, 2010 | Computers & Internet
9600 graphics card compatible for asus p5gz
hello, the 9600 graphic card his compatible if you are using AGP slot.
Aug 10, 2009 | ASUS P5GZ-MX Motherboard
Remote stuck in express card slot
Hi ,
Take a professionals help .
Mar 22, 2009 | HP Computers & Internet
No vedio
If a wire touched the side of the video card and there was a spark then that wire shorted something out. The video card is likely bad now and it is also possible that there was damage to the motherboard. If the motherboard still work then a working PCI video card or AGP video card would work. If there is damage to the motherboard from the short then it is possible that the PCI slots as well as the AGP slot will not work but there is no way to tell if that is the case without testing the electronics on the motherboard or plugging in a working video card to see if it works.
Jan 01, 2009 | PC Chips M963GV (V3.3A) Motherboard
My agp slot is not working
hi im wesley. your slot either got damaged or you can try enabling it in the bios if it might of been disabled.
Jul 11, 2008 | AOpen AK79G-VN Motherboard for AMD
Mother board asus A7V8X-LA
then that video adapter IC (integrated circuit ) in the motherboard which is located near the AGP or PCI express slot is in problem just visit the motherboard technician & get replaced that one ..
it will work ...
the cost of it is some what higher i think to repair .....
just once you visit the motherboard technician before you purchase the new board ....
Jul 04, 2008 | Computers & Internet
AGP card support
Hi, Unfortunately no AGP slot nor PCI-E. The Gigabyte GA-8I845GV motherboard has only 3 Expansion Slots and all of the are PCI (33MHz & PCI 2.2 compliantt). From their website, here's an image of the motherboard http://www.giga-byte.com.tw/FileList/Image/motherboard_productimage_ga-8i845gv_big.jpg It has a built-in Intel® Extreme Graphics Engine (845GV chipset) for video with max of 128 mb shared memory. Should you wish to install an add-on 3rd party PCI video card, Inno3D FX5500 256ddr PCI slot tv-dvi are still available (at least in my location) for an equivalent of about 3.5K INR (80USD+). Hope this gives you an idea. Good luck and kind regards.
Aug 19, 2007 | Gigabyte GA-8I845GV-C (GBSA4LB)...
Intel D845GVSR Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
