Question about Cameras
How to fis stuck lens on a canon ixus 75 - Cameras
  • Anonymous Apr 03, 2008
    My sony Cyber shot's lens are stuck don't want to go in or out. sometimes i need to help it to go out but still it doe not work, help me please where can i send it to for repairs.
    Hennie
    0845809018
    Scholar:
  • 198 Answers
I just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Posted on Apr 02, 2008
My canon ixus 75 has no power.
There are many ways to troubleshoot this problem.
First try to insert new batteries and then tap on the sides of the camera and turn on the camera. It will switch on if the problem is due to loose connection.
Secondly, clean the battery terminal before inserting new batteries and check through a multimeter, whether the battery terminal is receiving the power properly from the battery. If there is no power, you need to contact canon to get the element replaced. If there is power in terminal and still not switching on there is some chance that lens is stuck inside, and it is not allowing to switch on. So clean the lens and try to turn on the camera it will work fine.
If you still have the problem then it tends to be the problem of the circuit board inside the camera.
Hope this helps.
Shane
Feb 02, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Turned on ixus 75 and i have a black screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A of the link.
Dec 23, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon ixus 75 is not turning on properly the zoom lense is stuck out and wont retract. When i turn it on it says "lens error reset camera&quot
OK, assuming the batteries are ok, the problem is within the mechanism for the lens being too 'binding' while it operates.
Sometimes, people put their finger on the barrel of the lens when it retracts or extends.
If you reset the camera and it still does this, the camera needs to be serviced by Canon.
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/digital_cameras/powershot_sd_series/powershot_sd500?pageKeyCode=requestRepair
Jun 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon ixus 70 all showing a fuzzy dark spot??
clean the lens,get it serviced the lens as well as CCD.
Apr 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error,,restart camera.,,the lens wont go back in ,,and the camera will not work,,,its like the lens is stuck,,,can any one help please!!!
Did you try replacing the batteries? If that's not the problem, then it might just be stuck. Look to see if the lens is a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
Aug 01, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
When I turn my canon ixus 75 on I see a black sreen is all the camera functions. Viewing the already taken pictures I can see them all. When I take a picture it shows in view mode a balck picture. I guess...
No, if your camera is an Ixus 75, it's more likely that you're experiencing a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 15, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon ixus 75 digital camera reset?
Hi
What you are seeing is just an error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Apr 07, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Hi
There is no camera reset for this model, what you are seeing is a generic stuck lens error message.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from
Darntoothysam com
Sep 14, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Mar 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
97 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
