Question about RCA OPAL M4001 MP3 Player
Back light went out
I barly had the thing for a month then the back light slowly went out.
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 25, 2008
I have a 99 volkswagen gti automatic i bought it about 4 days ago 2 days after i bought it the checkegine light ha went on i can hear it has a exhaust leak an it rattle dont know if thats cause the exhaust...
For the slow pick up of speed, change the EGR valve. A bad exhaust Gas Emissions valve will make it impossible to pick up speed or climb a hill of any kind. Fix the exhaust system leaks also, That could make the Oxygen sensor not work properly and cause the check engine light to come on. Once you've done all repairs, other than what I've told you, the light will not go out on it's own. You need to take it back to Auto Zone and have them turn it out electronically.
May 06, 2017 | 1999 Volkswagen GTI
Check engine light went on
please give me model and year ,,,, did 10 years in honda so lets talk
Feb 13, 2012 | Honda Civic Cars & Trucks
One month ago I bought a rival 0.9 cu ft digital oven,model rgst902 ,I only use it mainly to warm things up, I was in the process of cooking something for five minutes,when I went to get the food out the...
I have the same model, after 2 days of normal operation it has stopped working. No lights on the dislay at all and the keypad is unresponsive. If you open the door the light comes on and the turntable slowly rotates. Im taking it back.
May 11, 2011 | Rival Microwave Ovens
I have a 05 Magnum with around 170,000 miles on it. The ABS and ESP lights are on as well as the engine light. The ABS and ESP lights were on for about 4 months and when I slowly went through a 10"...
have a fault scan done by a reputable shop or auto parts store. Anytime lights come on indicates a fault was tracked by OBII. You should get addressed ASAP when lights come on. Driving 4 mos. could've caused major damage. But in this case I think it was a low voltage issue that triggered lights, regardless, get scanned and address the issue correctly.
Jan 09, 2011 | 2005 Dodge Magnum
My car was having trouble starting, slow to turn, sometimes stalling out imediately after starting. Yesterday I went to start the car and it wouldn't start. Lights kinda flickered, but absolutely no...
check the earth lead connections to the engine from the car body, undo them, clean them up, and re assemble, then check the electric connectors to the starter motor the same way, check also plug connector is securely pushed into back of alternator.
Another thing to note, you mentioned the lights slowly dimmed after fitting new battery, this could indicate a major short circuit. good luck, P
Apr 28, 2017 | 2001 Hyundai Sonata
Ink jam in Epson 2200 printer
First try to print something. You never know it might work. Also you might try very carefully applying a small amount of sewing machine oil on the bar the print head is attached to then again very carefully and slowly move the head back and forth along the bar. It might just be that the bar is dirty and dry and needs a little bit of lubrication.
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
Dell Wireless Mouse dead
now mouse is open & clean by isoprpile & check battery conector after check now mouse its working.
Aug 25, 2017 | Dell Wireless Keyboard Optical Mouse w0147
2003 Air Conditioner not blowing cold air
If it goes down again,take it back to the mechanic.He will shine the system with a uv light to enhance the dye and find the leak..Good Luck!!!
Aug 06, 2008 | 2003 Hyundai Santa Fe
RCA OPAL M4001 MP3 Player Logo
14 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
