Question about Motorola Mobility RAZR V3
How do I change the display?
I would like to change the picture on my RAZR display. I do not remember how.
Menu
Settings
Personalise
Wallpaper
Change
Posted on Apr 02, 2008
SOURCE:
Black screen on RAZR V3
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 02, 2010 | Motorola Mobility RAZR V3
How do you fix the white screen on a motorola razr? I have tried to reset the battery and reboot the device, however, all i get is a white screen screen. The phone works find, just now display (very weak...
Good luck.
May 11, 2010 | Motorola Mobility RAZR V3
The picture on the screen as all fuzzy and cant get a clear picture without having a shadow or it being fuzzy
Do you have a led or crt display? It could be just your display settings. Go to control panel /display properties /setting tab / and try changing the screen resolution. If no difference try the color quality. You can change the color bits without hurting any thing. Just remember what you changed it from and to.
If this doesn't help maybe you'll need a new screen.
Aug 17, 2008 | Computers & Internet
Razr v3
when the phone ask for the unlock code then press the menu key it should now be asking for the security code if you have not changed it , it dhould be 000000 if you have let's hope you remembered it otherwise you will have to take the phone to a mobile service center and have them reset the code for you.
Apr 05, 2008 | Motorola Mobility RAZR V3
Front cover display
If you go into setting and then go into what I think is called display settings then you may be able to scroll down and then it may say "Brightness"
You should be able to change it like that.
If its not under display settings then its deffintly under somthing else in settings!
I owuld tell you the EXACT way to do it. But my phone got droped into water so its hard to tell you becasue the buttons wont work..
So therefore I have to try remember the instructions of my heart. I hope I helped you with your problem, and I hope it wasn't a bit to late :)
Jan 24, 2008 | Motorola Mobility RAZR V3
Changing owners/SIM cards
ummm the razr dosnt have a SIM card. That is a 64mb memory card for MP3 and pictures....
Jan 18, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Unlock Cingular LG CU500 for Cellular One
The LG CU500 is a 3G phone I think. You may need to change your SIM CARD to 3G. I had a razor and my Sim didn't work with the LG CU320 I bought. Also unlocking a LG phone is a little more troublesome that other phones. I found a solution on the web. sorry I don't remember the website address, but it comes up in any google search. Hope this helps.
Good luck
Dec 27, 2007 | LG CU500 Cellular Phone
External display screen problem...picture stuck
Hi, Have you tried removing the battery? If not, remove it, wait a few minutes, refit the battery and reboot the phone, its worked for me before with a different problem. Paul.
Sep 04, 2007 | Motorola Mobility RAZR V3
Display name
If the At&T banner is in the upper left of the display, it is read from the SIM card.
Aug 06, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
