I have a mickey mouse/donald duck wrist watch that has a metal expansion band that says made in hong kong. The watch back itself just says stainless steel metal bezel with a number and a blue tag with ref no. The face of the watch says lorus quartz and under the characters walt disney productions
SOURCE: I have purchased some cheap wrist watches from
mcdevito75 here, I'm figureing you have only one (1) button on your watches, some, even cheap digitals have two (2) buttons, one of which is ususlly for a light. Some have two (2) buttons, one says MODE the other says SET. For one button (1) digitals, This will usually say set, when you press this button you should see the display change, to month then press set agin to see date, press set again to go back to time of day. NOW!! look for a DIMPLE, an INDENTATION on the side of the watch fairly close to the other button, press this DIMPLE in with a tooth pick, pin or the point of a pen, this is your MODE, press once, see the display flash, now with the set button, set whatever display is flashing, press MODE again, set this next display, when all displays, Month, Day, Date and time of day, hour and minute are set, press MODE again to see steady display. when you press set now, you can see the corrected display, press the set button for each display you want to view until you come back to the time of day display. That"s it.
SOURCE: I am trying to set
You can download instructions from the Lorus website at;
http://www.loruswatches.com/instructions.asp
Best regards.
SOURCE: i have a lorus mickey
You may need to have a local jeweler who has a watch press to put it back on, If you put to much pressure on the inside of the back, it may be warped. A knowledgeable jeweler should be able to fix that issue also.
Thank you for contacting FixYa..
Jewel
SOURCE: what battery do i need
CR920 3V + is the battery you need to buy.You can buy any A+ 3v battery it will be of same size.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: need to replace battery of
Try to find a watch repair shop (sometimes called clock & watch shops). Also, many jewelers replace batteries and do watch repair.
