Sa-ex900 de technics
Hi,i have an amp.sa-ex 900 and it doesn't turn on , i heard " clic" wen i push the button, the display doesn't light "on" and " help" light ,still flash on and off ?? nothings happen? no sound, no display.i bring back my amp to the repair shop,were i bought it ,and they never find the probleme.the probleme start in a party at high volume,he stop and never restart thank you very much.......sorry for my english i'm french canadian.
  • 4,234 Answers
These systems use a large Ic for the output amplifier section. There are 2 of them inside. These amp packs fail and are not cheap to replace. Figure about $65-$75 for the replacement pac plus a labor charge. I have repaired a number of these in the past. These sets sound good but are expensive to repair.
Dan
Posted on Apr 02, 2008
SOURCE:
Technics sa ex400 help reset light staying on
I to have a Technics SA-EX400 Receiver, The reset light stays lit also, I assumed it is normal. When I push it, it says operating normaly...
Jan 04, 2012 | Technics SA-EX400 Receiver
I have a Sa-ex900 amp hooked up to Television ,vcr and dvd player. When I turn the amp on and want to play the tuner , the television bleeds through. In fact TV plays through all buttons except VCR1
it seems to be ,you have a possible wrong connection..I
may I recommend you to check the connections in accordance with my model connection procedures given below and correct if something is misconnected..
I believe Your Television ,vcr and dvd player all connected to each other thru Technics Receiver itself (not directly connected to each other ) and whenever you want to listen/watch any of it ,you make a selection thru Receiver..
** in order to do this both DVD and VCR 's "2xRCA audio" and "1x RCA Video" cables for "IN" and "OUT" should go to Receiver separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected )
** Additionally your RECEIVER's prefably only "1xRCA Video Output " should go to TV to watch the video of both DVD and VCR (audio will come thru Receiver.)
Ok, now Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV .( every TV has different type of Audio out jacks )
** to "TV input "or "AUX input" or "Optic Cable input"
of your Receiver (whichever you want ,based on the necessary cables on your hand )
** than just switch to respective mode on
Receiver corresponding the connector you have used on the back of Receiver ..
There you go..Tv sound are on the
Receiver .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 07, 2011 | Technics SA-EX900 Receiver
Buna ziua ! am o placa de baza l7vmm2--mai precis socket 462 la care nu gasesc drivere free nici de sunet si nici video ; as dori daca se poate sa ma indrumati sa gasesc aceste drivere ; va multumesc...
uite aici
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
clic pe Downloads si acolo o sa le gasesti pe toate;
nu uita sa accepti raspunsul si sa dai o testimony.
Feb 21, 2011 | EliteGroup L7VMM2 Motherboard
Hi. I have a Technics SA-EX500 Receiver, which still works fine, except that the display light has gone out completely. I'd prefer not to replace the receiver only because of a light. Is there any way to...
hi, yes the digital screen is replaceable, but youd have to completely take it apart, and youd have to find a broken one on ebay to scavage for the part. do you have the remote? do you leave it in the same mode mostly? id experiment with the modes, and then keep the remote out the kids hands and maybe put something over the buttons on the receiver to keep the settings from getting changed. you might even just go with the presets like dolby surround or movie mode. right now on ebay, there is 1 and its not broken, so keep an eye on that. the other option would be to buy the working one on ebay and use this one as a sub amp or auxillery for sending music to the rest of the house, lots you could do with it!
good luck!!!
Jan 31, 2011 | Technics SA-EX500 Receiver
Overload
Check the link below first. Post any additional questions here and I'll respond.
Thanks,
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Aug 29, 2010 | Technics SA-EX900 Receiver
Como iniciar el escaneo de un documento desde el ordenador ?
Usando el software de la impresora
1 Encienda el ordenador y la impresora, y asegúrese de que estén conectados.
2 Cargue el documento original. Para obtener ayuda, consulte "Cargue un documento original en el alimentador automático de documentos" en la
la página 24 o "Colocación de su documento original sobre el cristal del escáner" en la página 25.
3 Haga clic en Inicio → Programas o Todos los programas → Impresoras Impresoras Dell → Dell Photo AIO
→ 964 Dell All-In-One Center.
La Dell All-In-One Center abre.
4 Haga clic en Ver presentación preliminar para ver la imagen escaneada.
NOTA: Si el tamaño de la exploración (que se encuentra en la parte inferior derecha de la ventana de vista previa) aparece en rojo, lo hace
que no cuentan con los recursos del sistema disponibles para realizar la exploración en la resolución o el tamaño que tienen
seleccionado. Para corregir este problema, reduzca la resolución o el tamaño de su área de escaneo.
5 Ajuste las líneas punteadas para encajar alrededor de la parte de la imagen que desea escanear.
6 En la Enviar imagen escaneada a: menú desplegable, seleccione su destino de escaneo.
7 Para personalizar aún más su trabajo de exploración, haga clic en Ver más opciones de escaneo.
8 Cuando haya terminado de personalizar la imagen, haga clic en Escanear.
Oct 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
Amplificador panasonic modelo sa-he7, se pone en error f70
rafatecnico amigo mio el error esta en la placa de coneccion de dispositivos auxiliares por favor revisa soldaduras de los dos transistores de potencia que se encuentran juntos y de los dos transistores de acople de los de potencia, si se encuentran bien entonces alguno de ellos esta averiado en cortocircuito o abierto
Jul 29, 2009 | Technics Audio Players & Recorders
Could anybody tell me what F70 means ?
You must have air flow through this unit!...accordianman
Dec 04, 2007 | Technics SA-DX850 Receiver
134 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
