Dead Drive I think the firewire cable was plugged in backward and the unit powered and no lights just dead.  Any solution?
  • 449 Answers
I will advice you to change the logic board of the hard drive i.e the panel of the hard disk. good luck
Posted on Apr 02, 2008
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
... no drive motor sound
No drive motor means that either the motor is dead or the interface inside the case has failed. Take out the hard disk and put it directly in a desktop - if it fails even there then it's truly dead , junk it.
Mar 06, 2011 | Rocstor Storage Rocstor ROCPRO 400 AV 3.5"...
Hello I hv an Acer aspire 4702z model z01 who's
remove the side of the computer and make sure the power connector is plugged in to the drive. if it is not then plug it in and the problem is solved. if it is the drive is dead or you have a faulty power supply try plugging in another power connector ... if it is an ATA power connector it has 4 wires and usually a white plug but not always white. there is also a dat cable called a ribbon cable and it looks flat 2 inches across and grey. if it is a SATA drive connector it will look like a thick cable with a black plug coming down from the top of the computer where the power supply is. There are 2 cables plugged in to the drive the bigger plug is the power cable the one with the smaller plug is the data cable usually orange or red. Make sure everything is plugged in if it is the drive is mostly dead. you can buy a new drive for around $25 at a computer store. easy to replace... i hope this helps
Mar 24, 2010 | Acer Computers & Internet
BIOS update has killed my Netbook!
BIOS updates should only be done by certified technicians, if you put the wrong version on your system, lets say even 1 earlier version, there is potential that your computer may never start again.
I would contact Acer, is your machine still under warranty?
May 31, 2009 | Acer Aspire One PC Notebook
Hi, I have a Directv HD HR22-100 receiver that I think might be dead. It won't power on, when I plug it in the lights in back flash for a second thats it. I've tried resetting unplugging/plugging. I don't...
unplug all the cables from the back except the your video output ( hdmi, component,) restart the receiver. if u still have the problem then it is dead. if it starts up there is a problem with the cabling or dish and your will need a service tech.
Jan 02, 2009 | Directv (R10) DTV Receiver / 70-Hours...
LaCie drive won't turn on (blue light doesn't go on)
I doubt your hard drive is dead, even if your HD was dead the blue light would go one. It has to be the internal controller.. Your best bet is to get a HD enclosure and put your old drive in there. I've burned through 3 Lacie cases, all with similar problems..
Ciza
Sep 27, 2008 | LaCie (300770) 250 GB Hard Drive
Iomega HDD2H Exteral USB/Firewire Drive
Exactly right. This has happened to me on two occasions, renew the power transformer and that will solve your problem.
Sep 08, 2008 | Computers & Internet
HD will not start completely...
CLICKING SOUND IS THE HARD DRIVE ACTUATOR ARM THAT IS FAULTY.DEAD HARD DRIVE. CAN YOU SEE THE DRIVE IN DIVICE MANAGER?? IF YOU DONT SEE IT THERE IT IS DEAD AND HAS NO HOPE.
REPLASE THE DRIVE (SORRY)
May 20, 2008 | Acomdata 250GB External Firewire HD 250 GB...
Canopus ADVC 110 converter box not working
Plugging in the FireWire backward, especially if it's the 6-pin FireWire, will damage the unit's hardware. You need to contact technical support to arrange for repair.
Mar 11, 2008 | Canopus ADVC-110 A/D Converter...
Dead, plug in, powers up, goes dead
This is the typical way that drive belt problem occur. The mechanism needs some slip to accomodate the changing reel speeds as the tape plays, but if it slips too much, the reels don't move at all, the processor thinks there is a problem and turns off.
Time for a belt job.
Nov 15, 2007 | Panasonic AG-1980 S-VHS VCR
Computers & Internet Logo
119 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
