Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 when I print and copy there is no picture on the paper
  • Avondale Fleming
    Avondale Fleming May 11, 2010
    Hmmm.... do you mean that the text prints but images do not?
    Or that nothing is printing or copying at all (blank pages)?
    Problem Solver:
  • 11 Answers
Your ink cartridges have dried out. Replace the black to confirm this prognostication and, if black works, replace color also. If you are into refilling ink cartridges youself try soaking the black one in 91% rubbing alcohol in a small ziploc type bag for several days. when the alcohol becomes ink colored, remove the cartridge from the baggie, dry it with tissue paper, reinstall it in the printer and up to 3 times run a clean the nozzles page until it prints a solid black line. Repeat with the color cartridge. Good luck.
qwester1
Posted on Aug 21, 2008
Blue lines at the bottom of a coloured pictue I copied
try cleaning the print-heads from printers menu
you probably have a goggled print-head
Apr 27, 2010 | Lexmark X5150 All-In-One InkJet Printer
Nothing coming up on the copy
Hi There, when you mean copy, do you mean copying from the printer to the computer, or from the printer to paper. If from printer to paper, try checking the settings on the printer. It may be copying to your computer in a my pictures folder. Try that and see what happens.
Dec 02, 2009 | Lexmark X5150 All-In-One InkJet Printer
MY Lexmark X5150 All-In-One InkJet Printer Problem
HI try this its from the lexmark web site
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
How to Perform the Hardware Test on the Lexmark X5150 ID:ENUS3744
Using the operator panel on the printer:
1. Press the Option button 10 times until Cartridges appears on the LED display.
2. Press the + button 4 times until Self test appears on the LED Display.
3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
May 06, 2009 | Lexmark X5150 All-In-One InkJet Printer
My lexmark x5150 printer won't print the last two inches of printing on the right hand side of the paper. how do I fix this?
Is it from every progam/application? If it's only from MS Word for example, it could be your margins.
If it's from all applications, maybe your paper size is set to something other than what's really in there?
Steve
Feb 26, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150 color printing issues
Sometimes ,poor print quality may be due to ink build up in the maintenance station ..
Your ink cartridges stay in the maintenance station when not in use. Depending on the printer model, the maintenance station may be located on the right or left side of the printer. NOTE: You do not need to remove the cover in order to access the maintenance station.
To access the wiper for cleaning purposes:
Unplug the power cord from the back of the printer.
Move the ink cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right-hand side of the printer.
Take a warm, damp paper towel or napkin and gently clean the wiper on the right-hand side of the maintenance station.
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 won't accept paper.
More then likely with it doing that. Something is in the paper path blocking one side of the paper.
Feb 23, 2008 | Lexmark X5150 All-In-One InkJet Printer
Printer has suddenly stopped printing envelopes
Just fixed it thanks to Lloyd at Lexmark.com Go to Technical Support > LIVE CHAT. To print envelopes all I needed was to check the print in "Black" only button. Under Quality make sure the Print Color images in Black box is checked, select Apply and OK.
Jan 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 No printing
uninstall the printe driver,then try reinstalling the printer back.if no luck,change the usb cable or printer cable as the case may be,if doesn't work,try using the printer on a friends machine. did it work?let me know. eyo7 eyoifiok2005@yahoo.com
Sep 01, 2006 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
