Question about LG WM-2277HW Front Load Washer
Washer I am having a problem. The LG Trom washer is like 2 years old. It was working fine earlier today. Then suddenly It says "OE" and the door is jammed. It is full of water. I turn it off. I turn it on. I run it again and it gets down to about 19 minutes to go and it says OE again and is full of water. What can I do?? I called BEst Buy and they said look in the internet-LG My email address is anniebrownie123@yahoo.com. Sincerely Anne-Marie Brown
Anne,
The lint filter is clogged preventing the pump from draining all the water from the tub. Open the little panel on the front lower left of the machine, unscrew the lint filter and clean it. Make sure you drain the trapped water first (before you remove the filter), by pulling out the little rubber hose (you'll see it) and removing the plug from the end.
BW
Posted on Apr 04, 2008
Lg trom. It says oe
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 13, 2011 | LG Washing Machines
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
LG Trom wm2077gw OE error code and won't come off and empty macine I washed a comforter and it shredded part of it and is stuck on OE what does this mean and how do I fix it. Thanks
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
May 20, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WM-2277HW Front Load Washer Logo
148 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
