I Have a Xerox colour printer 621 and getting the error message (power off, wait 5 seconds then switch on (15-384) or call for service quote on the above fault code) what dose this mean?
  • Peter Hodgson May 26, 2008
    I have a A620 with the exact same error message. Currently looking for a solution.
    Problem Solver:
  • 8 Answers
I rang FujiXerox, and because the machine's service contract has expired, they refuse to service it - no matter how much I pay them! So I'm a bit stuck.
Posted on Sep 20, 2009
  • 106 Answers
Your printer power supply internal is not proper, get help from service provider by telling them error code (15-384), if possible they will try tell u solution online or will attend the complaint.
Posted on Apr 02, 2008
Xerox Phaser 7760 shows the error 004-350, what can I do?
You can find answers to your Xerox questions at .
Solution : Power Off the Printer, Wait 45 Seconds, Then Power On the Printer Some problems can be resolved by powering the printer OFF and ON.
WARNING: Only use the power switch on the printer to power the printer OFF and ON. Damage may occur to the printer if power is interrupted by other means.
CAUTION: When cycling power on the printer, any incomplete jobs in the queue will be lost and will have to be resent.
  1. Power OFF the printer using the power switch located on the top, right side of the Control Panel.
  2. Wait approximately 45 seconds, then power ON the printer.
Oct 23, 2013 | Xerox Phaser Office Equipment & Supplies
Xerox Phaser errors 09,005.49, 09,006.41, 09,007.42, 09,008.43
This procedure will clean errors like Note: type errors 09,005.49, 09,006.41, 09,007.42, 09,008.43 ('Ink Loader Fault - respectively cyan, magenta, yellow, black)
Start disconnecting the power cord for ten minutes , then remove the black stick check it and put it back. Ensure you are using original cartridges.
Turn the printer on, to enter the Service menu:
1. -You can access the menu using the FRONT PANEL:
  • Press the down arrow, select "Troubleshooting" from menu and then press OK
  • Press the down arrow until you get "Maintenance Tools" and then press OK
  • While holding the arrow at the top, also press the down arrow at same time, to access the hidden service menu.
  • Scroll down the menu until getting "Enter Diagnostics" and click OK. Wait about 20 seconds, then go to Step 3
2 - If you can not Access the menu because the printer is stuck with the error message on display.
  • If the printer is on, turn it off and wait 10 seconds. Turn the printer back on.
  • Wait to see the Xerox logo on display.
  • Before Xerox logo getting steady on display, press and hold the Back button (back) and 'i' (Help) on the Control Panel.
  • Hold down both buttons until the display shows "Beginning Initialization Service Mode". Release the button and the printer will restart showing the menu "Service Diagnostics".
3 - Scroll using the arrows until "Function Menu" appears and press OK
4 - Scroll using the arrows until you get the command "Clear Fault ISC" and press OK twice to confirm.
5 - Now push the "back" button on the control panel (usually at the left), then press "Exit Diagnostic", then OK twice to confirm.
6 - The printer will restart, and the error message will be gone.
7 - Remove the sticks, check them and load them back correctly.
If the error does not clear, then it is due to a fault, in which case contact Xerox technical support at the number listed on the owners manual.
on Jan 30, 2010 | Xerox Phaser 8550DP Printer
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Hp laserjet 3055 has error message on copying "50 fuser error, turn off then on". Restarting brings on the same message when copying.
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the cabling connections to the heating element.
4. Turn on the power and wait for the all-inone to initialize.
5. If, the error persists, replace the fuser.
NOTE The device power mustremain off for at least 20 minutes forthe fuser to cool down and correctly reset.
Turn off the power switch, wait at least 20 minutes, and then use the power switch to turn on the all-in-one and wait for it to initialize.
Aug 23, 2011 | HP LaserJet 3055 All-In-One Printer
I get an HP error message on 2600n printer saying "57 Fan Error". Is it fixable?
57 Fan Error
Turn off then on
The device has experienced a problem with its internal fan.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.The fan is not replaceable. Replace the engine.
Jul 11, 2011 | HP Color LaserJet 2600n Printer
Xerox work center 7335 code error : 005-285
Solution : Power Off the Printer, Then Power On
  1. Power off the printer using the power switch located on the front, right side of the machine under the Control Panel.
  2. Wait until the Touch Screen becomes blank.
  3. Press the power switch again to power on the printer. The entire power on process (to power on and complete a self test) takes less than 45 seconds. Certain functions of the printer, such as copying, will be available before other functions.
If this fails to solve your issue contact service.
Hope it helps!
Feb 26, 2011 | Xerox WorkCentre Pro 123 Copier
Xerox WorkCentre XD155DF front panel error code "L 6" What does that mean and what is te repair? It occurs during power on and will not continue to power up after the code is encountered.
Hello there breinhart.
Here's your geek-steer ...
Per manufacturer's support page, your device "Xerox WorkCentre XD155DF" is no longer made or sold by Xerox, therefore I'm presuming it's maybe getting a little long in the tooth.
Unable to locate error code "L 6"/"L6" for this device. However, per the "XD Series" user's guide, errors L1 thru L5 provides suggested solution of what's quoted following. Logic dictates L6 would have been paired up right alongside if not for this being an earlier published parent document to your later ...155DF suffix'd device.
Switch OFF the Main Power.
Wait approximately 5 seconds.
Switch ON the Main Power.
If the status code continues, call for service.
... which in tech parlance is an age-old, fundamental-as-they-come procedure known as a "reset/reinitialization". Which actually, right up to present day, is a surprisingly often successful remedy.
If I were you, I'd first try a quick reset/reinitialization as guide instructs. If/when that doesn't remedy, start from scratch:
  1. Check for/download latest driver(s) from support website
  2. Uninstall device's software.
  3. Turn off device.
  4. Unplug device.
  5. Wait 10 minutes.
  6. Disconnect all remaining cables/cords (both ends).
  7. Inspect for damage/wear and clean each cables' end fittings.
  8. Reconnect all cables/cords.
  9. Reboot.
  10. Perform a registry cleanup.
  11. Reinstall device using latest version software/driver(s), carefully following manufacturer's installation checklist.
That's just about as anal-retentive and thorough a reset as you can accomplish. Many would think it's too anal, but not me. I've discovered over a long period of time, from long-ago up to this very day ... printer type devices are THE most persnickety of them all. They're the house-cat of the PC/IT world ... vay'we, vay'we scay'we!
If still problem-ed, I'm sorry to say there's nothing much else I can offer as a solution, other than what the manufacturer's guidance is: "call for service".
Good luck to you, and please post back ...
  • to let me (and interested others) know how things worked out,
  • if you have any further questions,
  • to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig) Puget Sound, WA USA
Oct 04, 2009 | Xerox WorkCentre XD155DF Laser Printer
Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Are the connectors securely
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Jan 31, 2009 | Xerox Phaser 6125 Laser Printer
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
117 people viewed this question
