Question about Canon T70 35mm SLR Camera
Film won't load...
My film won't load in my camera. I did it exactly like the manual said, but no luck...could it be my batteries?
    Scholar:
  • 85 Answers
Check for batteries, film pressure plate on the back door of the camera, film leader and perforations ,freeness of the spool of the film cartridge,.
Posted on Apr 02, 2008
The new roll of film winds into the right spool upon closing back cover // brand new batteries displays 1/2 and ERR appears on led panel
Is the ERR blinking, and is there an additional blinking E on the display? If so, the film is not loaded properly.
The film is supposed to advance all the way to the take-up spool upon loading. The camera then "rewinds" one frame at a time as you take pictures. This way the camera knows exactly how many shots are left on the roll. Also, if the back is accidentally opened, the shots already taken are already in the can and won't be ruined.
If you need a manual, you may download a copy here.
Try cleaning the battery contacts and see whether the battery reads full with no film in the camera.
If problems persists, feel free to reply to this post and give any additional details.
Mar 04, 2012 | Nikon N75 35mm SLR Camera
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
I have a 35mm nikon camera. I've changed the batteries but the film won't load. how can i load the film?
Here is what to look at: Custom Function number 8, "Auto film load when back is closed", default setting is 1 disabled on 0 it is enabled. If you have the manual for the F80 (same as N80) look on page 21 and page 72 and 73.If that is not the issue check the following: With the new batteries does the camera turn on, Can you focus, does the LCD light up? All that will let you know if you are getting power to the camera. If the answer is yes then the film should load so now check the inside of the camera back. Does it have the pressure are and roller next to the hinge. If that is missing then when you pull the film to the red dot, close the camera back there is nothing to put pressure on the film for it to load.
Aug 06, 2010 | Nikon F80 35mm Film Camera
I bought a minolta 35mm camera..i dont know how 2 use it....i can load the film but dont know how to program to take pic.
if you could reply with the exact model of the camera I may be able to find a user manual online
heres a link to the minolta manuals http://ca.konicaminolta.com/support/manuals/index.html
Once you have the film loaded - you then need to set the correct aperture and speed for the light available to correctly expose the film - There will be a number of options and methods to do that depending on the model .
You may also need to get a battery for the camera -
Apr 05, 2010 | Minolta Photography
Screen is black and film won't load
If it's a 35mm film camera and you see nothing through the viewfinder, then as long as the lens cap has been removed, your camera has a locked up mirror.
You don't give any clues which exact model you have, but if it's one of the later electronic autofocus models with automatic film advance then the additional detail that the film isn't loading confirms that your camera simply has no power. Replace the batteries and all should be well.
If your camera does not have automatic film advance then you still almost certainly have flat batteries and just need to learn how to correctly load and wind the film.
Feb 28, 2010 | Pentax Photography
Can't load the film
Turn the camera on. Open the back. Insert film, pull it across to the red mark. Close the back.
Camera should load automatically.
You can get the manual at http://www.butkus.org/chinon/nikon.htm
May 22, 2009 | Nikon N75 35mm SLR Camera
Camera goes into Shut Down Mode & Flashes the Letter H
Hey sonax,
This H error message means either the film is loaded incorrectly, or there is an internal malfunction in the camera. To determine if the film is loaded incorrectly you should take the film and the batteries out of the camera then reinstall the batteries and try taking a picture without film in the camera. If the camera allows it then the film was loaded incorrectly and I would refer to the camera manual for directions on how to load the film correctly. If the H error message persists then there is most likely an internal malfunction and I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 23, 2008 | Canon Sure Shot 65 35mm Point and Shoot...
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
GOOD LUCK.
andy
amasseur at gmail dot com
Oct 03, 2007 | Nikon N75 35mm SLR Camera
Canon T70 35mm SLR Camera Logo
285 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
