Question about EnGenius EOC-3220 (EOC3220)
EOC-3220+ flash reset probs
Trying to help a friend out... we did the whole hyperterminal flash reset reboot thing on 3 diff EOC-3220+'s and all have same prob... it will not allow me to connect to it thru any ip address after flash reset
192.168.1.1 don't work nor does any other ip.
once in a great while the computer will obtain a dhcp address of 169.254.156.4 as dhcp server and I can ping that address but wont allow me access to the unit thru web browser. had 4 units total to start with... the first one worked like a charm flash reset reboot fixed it and had default ip 192.168.1.1 but these 3 here nothin.... any ideas?
  • Digger2k4 Apr 02, 2008
    Also using ifconfig command in hyperterminal I was able to see it shows ip of 192.168.1.254 and 192.168.1.255 as broadcast but cannot connect to those ips either.
  • Anonymous Apr 03, 2008
    oh its really apity that the technical support of this great company with a great crazy technology is very poor. really poor . the latest is that the same problem developed on my EOC 3220 EXT just few days ago. tried the hyperterminal resetin but dopesnt work. oh... the "#" sign never displayed talkless of ther last two other procedures. pls for how long does it take for the "#" sign to appear. pls any body that the solution should mail me at Ultraeniac@yahoo.com. See ya next time
Hi..
I had that problem too.. I scan the radio IP with Dude, software that come free for mikrotik.. and I got 192.168.1.245 for my radio. since that day I know that 3220 will go to that IP after flash reset. the mode will be Ap only, if you change to AP on operational mode than it will go to the standart Ip either 192.168.1.1 or 192.168.1.2
Hope this will help
Posted on Apr 16, 2008
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
How do I get into my engenuis eco-3220? Someone messed with the ip address and I cant figure it out at all...or it will let me ping then not let me ping...going crazy
There is no reset button on this model. To forcibly regain control of the configuration, you need a USB to serial cable, possibly a null modem adapter (depending on the serial cable), and a serial communication program like HyperTerminal or ZTerm for the Mac.
The manufacturer has incomprehensibly removed the detailed reset instructions from their website, but they can be found here:
http://www.keenansystems.com/engenius__senao_wifi_faq.htm
Look for the section titled "How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? "
Aug 30, 2010 | EnGenius EOC-3220 (EOC3220)
Resetting my EOC-3220 via serial cable
The # will only appear if you monitor the EOC through the power-up sequence. If you are cabling into a running EOC, that # has already gone by. By that time, you no longer need to wait anyway, just type.
If you can't type in the text window, you may have HyperTerminal set up wrong, or may have the wrong brand or model serial cable. The EOC is pretty good about accepting input when it is supposed to.
However -- as long as you know what the current IP address of your unit is, you should be able to browse to it over the main ethernet cable and make whatever changes you need that way. The MAC address allow table isn't going to affect your local access in any fashion, it only controls who can connect wirelessly. This may be faster than trying to figure out how your serial connection is faulty.
Aug 12, 2009 | EnGenius EOC-3220 (EOC3220)
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
My senao eoc-3220 is showing SSID as 802.11g-SSID. But it does not acquire an IP automatically. I tried using defaults but that does not work either. Trying factory reset does not work because the "#"...
Hi
I had the same problem. This may be as simple as pressing the enter button on your computer keyboard after all the activity stops. This brought up the number sign for me after which everything else in the reset procedure worked fine.
Dec 22, 2008 | EnGenius EOC-3220 (EOC3220)
Resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
a. Give this new connection a name. Ex: EOC-3610.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Dec 03, 2008 | EnGenius Computers & Internet
Resetting the senao eoc-3220 long range wireless access point/bridge
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
AP Mode Problems
Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
PHASE I
1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
(where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
Phase II
1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
5) And lastly change the default user and password of your AP.
Good Luck
Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC-3220 (EOC3220) Logo
609 people viewed this question
Top EnGenius Computers & Internet Experts
john smith
WTF Chuck.....
WTF Chuck.....
Jacqueline
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
