HOW DO I GET THE SETUP CDS FOR THIS EMACHINES W3400?
MY COMP IS MISSING ALOT OF FILES I CAN NOT DO REBOOT TO ADVANCE REBOOT .I HAVE NO STARTUP FILES OR BACKUPS PLS HELP
  • Mark Williams
    Mark Williams May 11, 2010
    What Kind of computer is it, what make, model, Operating System
    e.g. Windows 2000 Pro, XP, XP Pro,Vista Home, etc
  • 111 Answers
Buy a windows xp cd then reinstall the os
Posted on Apr 02, 2008
Is the eMachines Motherboard w3400 a good item
the problem with e-machines is that the motherboards are very cheap ones and they dont last very long
Feb 20, 2011 | AMD eMachines Desktop System w/ 17'' CRT...
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
NTLDR is missing. Press ctl+alt+del to restart.
I assume you are using Windows XP. This is what you do:
Windows XP users
  1. Get a Windows Installation CD. It doesn't have to be yours, anyone will do.
  2. Insert the Windows XP CD into the computer.
  3. When prompted to press any key to boot from the CD, press any key.
  4. Once in the Windows XP setup menu press the "R" key to lauch the Recovery Console to repair Windows.
  5. Log into your Windows installation by pressing the "1" key and pressing enter.
  6. You will then be prompted for your administrator password, enter that password. If you have none set, just press Enter without typing anything.
  7. Copy the below two files to the C:\ directory of the primary hard disk. In the below example, the files from the CD-ROM drive (which in this case is "D:\" are copied to the C:\ drive. This letter may be different on your computer.
    copy D:\i386\ntldr C:\ (hit Enter)
    copy D:\i386\ntdetect.com C:\ (hit Enter)
  8. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
If you have any more questions or this is not clear to you, just come back here and leave a comment - I'm happy to help.
May 22, 2009 | E-Machines eMachines Refurbished EMA...
Reformatting E-machine desktop computer W3115
Insert the CD to the CD ROM. Set the bios setup to boot using the CD-Rom. Space bar while booting up. If you got the setup press F8, choose NTFS to format the drive. Then go on with the Installation.
Mar 10, 2009 | E-Machines eMachines Desktop PC
Startup repair failed. cant get to startup screen
did you back-up your important files?, if you did, then you need to reformat your hard disk drive (hdd) and reinstall new system.  but if you didn't backup your important files, ask for help at the service center near you, cause it need another hdd to backup some files.  then if you have nothing to lose on your hdd then go ahead to reformatting. sometimes that error occur when it didn't undergo proper shutdown
Dec 14, 2008 | Dell Dimension E521 PC Desktop
NTLDR is missing
You need to reinstall your xp or use the restore cds /dvds that came with the laptop to repair the windows startup problem.
Files missing / corrupt.
May 08, 2008 | Acer Aspire 5100 Notebook
Re:// HOW DO I GET SETUP DISCS FOR EMACHINES ?
you have to reinstall the os xp or vista, if its branded pc the restore cd/dvd should be there and you can use it. if its compatible or assembled one you should purchase original or pirated xp or vista cd/dvd and boot from it to install os
Apr 02, 2008 | E-Machines eMachines Desktop PC
How do i get the setup disc or dvds?
Found other question....
The setup dvd is usually made when U turn the pc on for the first time. The system will want U to make them them called Recovery disks (dvd's).
Must be used machine and needs some TLC.
After shutdown, unplugged, open case and vacuum or blow out dirt. Clean fans and gently push connections to insure good connections. Power up to make sure all fans are working. Unplug and reassemble.
Boot up and run Disk Cleanup, then Defrag. Run MSconfig - startup tab and uncheck everything. Reboot.
The only thing that will shut down pc is overheating. If confussed, go to control panel to power options and read options, set accordingly.
U can create recovery disk by following directions in the Help and Support section.
Good Luck
Apr 02, 2008 | AMD eMachines Desktop System w/ 17'' CRT...
My comp is missing the startup files and i am missing bigfix programs how do i get the setup cds or dvds for the emachine i have now?
If system restore does not fix your computer, then you have hardware problems (overheating, faulty memory or CPU, or some other component). Start by looking at those possibilities.
Mike
Apr 02, 2008 | Computers & Internet
EMachines W3400 DVD not opening
Go to your control panel, systems, hardware, device manager and see if the device is reconginzed. If there is a "!" by the DVD drive, there is a hardware issue or driver issue with the device.
Aug 16, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
