Question about iLO (2 GB) MP3 Player
How can I remove write protection error from my flash though it hasn't any protection button?
Dear Tahiya
Best Regards
Muhammad Adeel
madeel79@gmail.com
  • 8,596 Answers
Disengage the hold/lock switch
Posted on Jul 05, 2008
Canon IR 3300 error code E000014-0000
this is fixing drive motor error
regards
Muhammad Ali
jak1980_pk@yahoo.com
Dec 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
My Canon copier, Model IR 400s, Shows the error code : E 000. What is the problem ? How can I Solve it ?
this is an error for the fixing temperature
check the thermal fuse or connector for the heater
thanks and regards
Muhammad Ali
Dec 11, 2013 | Canon Office Equipment & Supplies
My TV shuts off as soon as I turn it on...What is causing it to do this??
When it shuts off. Try doing what's called a self-diagnostic test. As soon as the television shuts try these steps.
Pressing on the front panel's 'INPUT' and 'MENU' buttons at the same time, and holding for 5 seconds, activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
-The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
-The flashing then pauses for approximately 1/2 second.
-The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
-The Error Code is repeated a total of 5 times.
-Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnostic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Apr 08, 2010 | Haier 20" TV/DVD Combo
Keeps shutting off
times.
Warm regards,
BearWeb
Panda Update not complete pop-up appears even after updating.
You can opt some better anti-virus software which can more efficiently scan you PC. Make sure it is an authorized version.
Jan 14, 2010 | Panda Internet Security 2009 - 3 User for...
Remove write protection from 1gb mmc memory card
You will see a little "button" you can slide up and down at the side. This controls the write protection. Just like it the other way and that should do it.
Sep 13, 2009 | Kingston flash memory card - 256 MB -...
No document in the copy of canon copier NP6317
Hi my name is Muhammad Kabir from afghanistan, I had a Nashuatec iR622J Copier Machine it had a paper jam problem and it was giving erorr massage to open left cover and remove the paper but when i was opening the left cover there was not even a small piece of paper inside of them even i checked the fuser unit but there was no paper what was the problem, the problem was with the sensors that they were not placed in their place and also the electricity lines had stoped the gararies of the fuser and when i removed them and put them in their own place the paper jam problem solved...if you need any more information please contact me this is my email id baktash_neumaticbeleive@hotmail.com
Best regards,
Muhammad Kabir Barakzai
May 11, 2009 | Office Equipment & Supplies
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
iLO (2 GB) MP3 Player Logo
416 people viewed this question
Top iLO Audio Players & Recorders Experts
Michael Vincent Cruz
Allen Benge
Level 1 Expert
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
