Question about Epson Stylus C43SX InkJet Printer
Ink i have epson stylus c43sx. the ink levels on the properties does not show the current levels of my ink cartridge. its as if its not detected what's wrong with it? pls i need help
  • Epson Master
  • 691 Answers
See my answer to your similar question:
t is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Posted on Apr 02, 2008
My epson stylus C90 will not print, red light and green light bling on/off continuously
YOU NEED TO DISABLE THE INK LEVEL MONITORS AFTER RE-FILLING THE CARTRIDGES. GO TO PROPERTIES, MAINTENANCE, VIEW PRINTER STATUS, OPTION AND CLICK ENABLE STATUS MONITOR ONCE.
Jan 16, 2010 | Epson Stylus C86 InkJet Printer
Shows replaced cartridge as empty
The cartridge chip needs to be reset to "full"; for this you need a chip resetter - this should have been done by whoever refilled the cartridge for you. You can get your own Epson chip resetter very cheaply on E-Bay.
Please rate this solution if it is of use to you
Feb 21, 2009 | Epson Stylus C43SX InkJet Printer
My Epson Stylus C43SX does not print without the black ink
I sympathise with your frustration - we all feel it. Epson printers, by design, will only work if all cartridges are present and correct. When you change a cartridge or carry out a head clean, the ink charging and head cleaning is carried out on all cartridges. So what you are experiencing is normal, I'm sorry to say.
My advice is to buy the cheapest compatible cartridges you can get - have a look at e-bay in particular. In the UK a set for the DX4000 would cost less than 6 UK pounds, including shipping. If you are prepared to buy several sets at once you can save a lot more.
Note for future reference that your query was in the C43SX section - make sure you post your queries in the right section, otherwise people who could help you may well not see it.
Oct 18, 2008 | Epson Stylus C43SX InkJet Printer
Ink Supply Problem
No, the Epson Stylus C43SX design requires that both cartridges are present and working i.e. not empty. If you wish to always print from one cartridge e.g. black, you can refill the empty color cartridge with distilled water and reset it to full. For this you will need a chip resetter (very cheap - see e-bay for example). Do not run with a dry reset cartridge - you'll end up with a damaged print head.
Aug 15, 2008 | Epson Stylus C43SX InkJet Printer
Epson c43sx current ink levels not shown in the properties
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Epson c43sx does not print
It is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
change the cartridge thats simple red light indicating you must change your catridge
Printer says no ink
I have a similar Printer. And similar problems crop up. Have tried cleaning the contact terminals in the cartridge slot? (You will notice a small PCB on the TO 38 Black ink cartridge) This terminal sends data to the Printer and then to the Status Monitor screen.If these contact terminals are dirty, or if your cartridge is not a Genuine Epson TO 38 cartridge but a generic alternate cartridge, then the PCB contact configuration will be different and so will send wrong data to the Printer Logic Processor. My suggestions are 1. Make sure yours is a Genuine Epson TO 38 cartridge 2. Clean the contacts in the Cartridge compartment. 99% your problem should be solved. Pravin Gupta, India guptapravin@hotmail.com
Jun 19, 2006 | Epson Stylus C43SX InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
