I am trying to share a printer with my wireless laptop
    Sergeant:
    Champion:
  • 326 Answers
U have to install either a wired print server and cable to pc - router - server, or install a wireless print server. follow installation instructions to install. The printer has to have an IP address to be shared.
Posted on Apr 02, 2008
SOURCE:
Hi there, i got a usb air card for my laptop and i want to send out a signal to my belkin wireless router (with a cable) so that it can send out a wireless signal and be able to put my wireless printer on...
Sure, I can help. First off I need to know more information. Are you planning on connecting the printer, through USB, to your laptop then sharing the printer from there to other computers? If so, it is a matter of adding that printer, going into the printer properties, sharing tab, and sharing the printer. Or are you trying to share your printer wirelessly? If so you may need to buy a wireless print server. It acts as a base to share that printer and then allow you to wirelessly find it and connect. If the above doesn't help please tell me the make and model of your printer, laptop, and wireless router.
Best, -Mind
If you need further help, reach me via phone at https://www.6ya.com/expert/clayton_0b2096930c0c699a
Aug 03, 2011 | Belkin (F5D7230-4) Router (587009)
Im trying to set up wired computer desktop to share my new s605 to my sons laptop wireless...do i need to use the CD enclosed with the printer and put it in my sons laptop to install the printer on his...
Yes you need to setup the printer as a shared printer using the printer driver CD.
Your shared printer and computer would need to be on your LAN and connected to a wireless router. The laptop will connect to the shares printer via the wireless router and LAN cable to the computer with the shared printer.
Please click on this link and follow my instructions to setup the shared printer.
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Jun 03, 2011 | Lexmark Interact S605 All-in-One Color...
How to add a printer in Vista
your best bet is to install network magic to control your wireless network. http://www.purenetworks.com/product/basic.php the essentials is the best option for you. it may cost $29.99 . from this site u can easily do this
Oct 02, 2009 | Office Equipment & Supplies
Wireless Laptop and Wired Desktop cannot communicate
Simply printer sharing should be enabled on both computers as well as file sharing.
Helpful Links
Printer Sharing
Jun 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Cannot share printer w/laptop(wireless)w/ PC
You need to share the printer. Go to your pc and open up the printers (Start button, Printers and Faxes). Right click on your printer that you want to share and then click sharing. Make sure share this printer is checked and list this printer in directory is checked. Now you should see the printer on the laptop when you click the Add printer and choose browse for printers or something to that effect. It will prompt you to install the drivers for this printer on the laptop. Click Yes or OK and you should be good to go. Make sure you have the printer turned on prior to doing any of this. You will also need the PC attached to the printer turned on when printing.
Apr 14, 2009 | Acer TravelMate 2480-2153 Notebook
Wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
Jan 16, 2009 | Computers & Internet
COMPAC LAPTOPS
  1. turn on the computer that has the printer attached.
  2. configure computer to share (start/settings/printer-faxes/right click on default printer/select sharing tab/ select share this printer/ apply settings/OK)(This computer must also be connected to the router so your laptop will see it as a network device)
  3. on wireless laptop, add printer
  4. when prompted select network printer.
For my wifes ease of use I purchased for $20.00 network magic which auto configured all my devices and monitored any access to my wireless router so I could choose who could access my open router.
Jun 04, 2008 | Compaq Presario 700 470024-192 Notebook
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Help please....printer name does NOT appear
You must have a network set up, and you must enable file and printer sharing on the desktop. The laptop and the desktop should be in the same workgroup. Some firewalls will cause this problem.
Start with the network setup wizard in Settings/Network.
Jan 25, 2008 | D-Link NETWORK CARD DFE550TXREF Network...
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
