My t.v. just shut off and won't come back on,
I just go this t.v. from a friend and I turned it on and it was fine. I have a window a.c unit, when i turned it on, the t.v. shut off and I could smell and odd smell
  • 5 more comments
  • BonnieMC Apr 03, 2008
    I opened the back of the t.v. up and found a black film on the wires, like something was burning
    I don't know anything about the circuit board, how will I know what I am looking for on the board.
    Checked the fuse, thats not the problem
    what are these new parts called and where would i find them
    Where can I get a service manual for my t.v. model number 7P5430W101
    hitting it, and jiggling the cords don't work, and have tried the hard reset, no success
  • 13,434 Answers
While its nice to know how to fix it yourself its still dangerious.
Theres high voltage going in there.
I would really recommend takeing the tv to a local professional
you can also find a repair service from www.fixya.com right under the top experts just put your zip code there if your in the us.
Basicly as the guys sayd most likely the powerconverter board or something else has burned.
Not an easy task to perform yourself in most cases and on top of that its dangerious.
so if you need more assisstance let me know.
Im trying to reach the Guru rank, so if you could give me a fixya that would be great thanks.
Posted on Apr 03, 2008
    Genius:
  • 3,422 Answers
You can bu the parts from HERE or from HERE
If you need any schematics you can get it from HERE
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Check the line cord. Wiggle both ends near the molded part.
TWO: Make sure you have power in the outlet by plugging a lamp into the same exact outlet.
THREE: Do a hard reset; merely unplug the line cord but leave it unplugged for 4 hours before powering up again.
The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If this does not solve your problem then the only solution to fix your the problem is to get it repaired by a technician
Goodluck,
Please don't forget to rate the solution.
    Guru:
  • 1,894 Answers
I think this is due to the capacitors that are going bad in your sircuit board.
it may be even resistors.
because your protection circuit is not working.
  • dewan nafees ahmed Apr 03, 2008
    protection circuit is the one that is responsible for protecting the CKT against all kinds of high and low voltages.
    first of all your TVs power section is faulty.
    and so when ever there is a power imbalance it is not able to make itself. stable.
    now what you got to do is.
    replace the power section with all new better components.
    then use a stabilizer to switch on your TV.
    don't use the power directly.
    this wil help you a lot.
    thank you
    the capacitor in the power board. or the power board if the whole power board is burt out,
    because if the capacitors wont work--ur filter ckt also wont work. --if filter is not working then you are prone to high and low voltages.
    you can find them at repairclinic or at applinace andother site from net.
    WARNING: if you are really handy in electronics then only u can try replacing by yourself at your own risk.
    thank you
    good luck
    Genius:
  • 1,226 Answers
Hello
Please examine the circuit board, and replace the busted spare parts. spare parts is cheap but also you can let the service tech to do the job for your safety.
melnavz
  • Televison & ... Master
  • 19,396 Answers
The power supply is gone, you need to replace it.
Posted on Apr 02, 2008
  • Ginko
    Ginko Apr 03, 2008
    That is a short, if you are lucky you just replace the wires and that is all. Leave the tv unplugged for a while before servicing it, there is always risk of electrostatic charges.
  • Ginko
    Ginko Apr 15, 2008
    7P5430W101 it is a philips remote control serial, not a tv. I suggest not to service your tv if you do not have sufficient experience. If you found a black film on wires, then it is a short it caused plastic to melt, as said. Nothing to do with pcb board, unless it has been damaged as a consequence of short, or the burnt lid was on this board. Cables and components will need to be tested for continuity with multimeter before being replaced.
    If you already identify the area in which the short happened, and it is a short between cables the only use you have for service manual is for haow to open your tv. In any case, if you post the tv number we can check for an online service manual or schematics/diagrams.
    Regards
    I know it can be an easy fix, but my suggestion is to call a repairman.
SOURCE:
FAN WON;T SHUT OFF EVEN WHEN UNIT IS TURN OFF WINDOW UNIT
The switch may have rusted a bit and won't let the switch turn off. Sometimes a whack with the side of your hand might jar it loose and turn off. Or the switch is bad and needs replacement. You probably got it at Lowes. Ask them to suggest a good repairman.
Jun 14, 2014 | Frigidaire 5,000 BTU 9.7 EER 115 Volts...
Why does my Kia Rio shut off while driving
My mom has a 2013 Kia Rio Car starts up fine but while you’re driving at a nowhere the car starts up fine but while you’re driving The car will Shut off but all the power still on when you turn the car completely off and wait for a little bit turn it back on the car will start but the RPM gauge won’t work you have to turn the car off again wait for a little bit start Pumping on the Excelerator while turning on the car in the RPM gauge works then it shows a check engine light but the car works fine After you park the car for a few hours turn the car back on the check engine light is off can anybody help me with this problem
Mar 29, 2013 | 2008 Kia Rio
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
RCA 50: HDTV, just started shutting itself off and won't come back on for several minutes or over an hour what could cause this
My friend had the same problem. There is some display bulb that is on its way out. They aren't cheap. Find a 2nd hand TV parts/repair shop, They usually have cheap used ones from discarded units, and will know what you need!
Sep 16, 2012 | RCA Televison & Video
Gbc heatseal ultima 65 won't turn on. It shut off while laminating a poster. It was getting close to the end of the rolls, but it just shut off and wouldn't turn back on at all. 4 Days later it...
GBC appear to just be a crappy company. I have a Heatseal H212, same problem. Worked fine then one day when I turned it on it never became "ready". I waited a while longer then turned it off.. except it wouldn't let me turn it off. I had to unplug it from the mains to get it off. After that, it would never turn on. Checked the fuse, it was fine.
Sep 26, 2011 | Gbc HeatSeal Ultima 65 Laminating System
2001 Yukon SLT, engine will not turn over - friends think it's the alternator. Battery is 2 yrs old. My friend tried to jump start it, that did nothing, still won't stay turned on. I got the...
Hi there !
I won't say its an alternator problem because the alternator only charges the battery when its on, And it should start with the jump cables even if the battery and the alternator are bad. your Issue is not clear. Does the car start when you jump it ?
Aug 15, 2011 | 2001 GMC Yukon Denali
E1 error code came on it was working fine till this morning.got it as a gift from my friend she bought it last summer. the remote stopped working we replaced the batteries still the remote won't work...
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Jul 10, 2011 | Haier hwr10xc6 Air Conditioner
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
I have a used Dell Inspiron 8200, it has not been cleaned out but it worked fine when I got it, I ran a System Restore and used it until about four days ago when the computer froze. I shut it off, (did not...
Severe corruption. Since you can no longer boot in any way in it it's going to be extremely hard to fix it. Better just reinstall Windows from scratch. Use the recovery cd that should have come with the laptop. If you don't have it then just use a disk borrowed from a friend and the key on the label.
Jun 14, 2011 | Dell Inspiron 8200 Notebook
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Ekse
