When you turn the key in the ignition, the ECU will ask the immobilizer if it can start thecar. If the signal is not sending then immobilizer error will show.There is a way to deactivate the immobilizer. The procedure is as follows:--
To deactivate the immobiliser just turn the ignition 3 times on and off and the immobiliser will deactivate .But if still the same problem then this could be the immobiliser read coil around the ignition switch or its a flat battery problem.
Thanks. you can rate this solution and show your appreciation.
The column-mounted theft deterrent module with integrated antenna
The transponder
The engine control module (ECM
