Question about Royal Office Equipment & Supplies
Paper shredder doesn't feed paper.....
My paper shredder runs when I try to insert the paper but it does not feed into the shredder at all. Any idas of how to fix this?
fellowesrep
  • 102 Answers
SOURCE: Rexel rdx1750 shredder jam
This is the available numbers for ACCO Rexel 0845 658 6600 or 01296 732466/732468 in the UK or you may contact by email mailto:informationeurope@acco.com and this is the web address http://www.acco.co.uk/
Posted on Mar 06, 2008
geemarie
  • 876 Answers
SOURCE: SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Posted on Aug 01, 2008
JayBlair
  • 328 Answers
SOURCE: UNJAM MY EMBASSY TS 60 SHREDDER
You have to remove the top cover. Look under the top and remove screws. Gently lift top and do not stress the connecting harness. carefully remove paper shreds. Unplug of course!!
Posted on Jul 22, 2009
  • 3 Answers
SOURCE: My shredder runs but won't grab the paper that I'm
Look down into the slot to see if the teeth are sharp. They should have little J-hook thingys that look like the teeth in your mouth. If it looks ok, give it some food to chew. If it burps it up, throw it away because its a junker and not worth your time.
Good Luck.
Posted on May 12, 2010
SOURCE: NoviTech Paper Shredder will not feed paper forward.
Solution 1 worked for me. I unscrewed all 7 screws, pulled apart the cover carefully. Beware, there are wires attached. you can lay it side by side.
The activator is the white plastic thing. You need to make sure that it sticks out and as the paper goes from the top, through the cover, it hits the white activator.
At the end of the white activator, you see it has some plastic to push on the metal strip. This engages the forward motion. You'll here a click if you test the paper going through. This click is the sound of telling the motor to roll forward.
I think it got knocked out of place when I tried to insert a CD into it. Luckily, I didn't buy another shredder because of the Best Solution in this forum. So thanks for your help!
Posted on Aug 01, 2010
Unit runs with nothing inserted into shredder
About 598,000 results (0.73 seconds) Search Results
    [PDF]Shredder Troubleshooting FAQ
    https://images-na.ssl-images-amazon.com/images/I/81GTHxKpz9S.pdf
    Make sure that the unit is securely plugged into a working outlet / socket. 2. If you have ... The shredder runs but it does not pull paper down. 1. Be sure the ... When ready to shred, be sure to insert material directly into the center area to start.
    [PDF]Instructions Manual
    https://images-na.ssl-images-amazon.com/images/I/71EUxqIkPNS.pdf
    you leave the shredder in the "Off" position whenever the shredder is ... To beginshredding, locate the switch on the unit and select the "Auto" mode (FIGURE 2). ...Your basic vegetable or cooking oil (nothing flammable ... a) While in "Auto" mode, the motor will not start running until paper is inserted into the feed slot. Set.
    General Shredder Troubleshooting - iThinkBlue
    store.ithinkblue.com/shredder-troubleshooting/
    Make sure that the unit is securely plugged into a working outlet / socket. ... While in "Auto" mode, the shredder will not run until paper is inserted into the middle ...
    [PDF]troubleshooting paper shredders - Ativa
Jan 31, 2016 | Shredder Office Equipment & Supplies
Runs in reverse and forward ,when insert paper blades won't let paper in
unplug it and then use compressed air (duster can used for pc's) spray this into unit and into teeth area. This should dislodge any unseen material.. (TIP - don't put any staples or clips in the shredder) even thou it says you can - this can cause a jam as well as not recognize paper. I recommend you get Shredder OIL to use 1 a month to keep your shedder in good condition
Jan 01, 2012 | Royal VF700 Cross-Cut Shredder
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Jun 04, 2011 | Royal VF1012mx Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
I have a Royal 7X Shredder which has developed a problem recently. The motor appears to try and run when paper is inserted, but the blades will only cut a 1/4 inch. The paper will not feed down into the...
I would definately say that you ahve some sort of jam in the lower half of the unit. If this is not the case, and you can see through it from bottom side up, then you have a belt slipping. There are 'toothed' belts that drive these. Most people call them timing belts, if you can get a hold of one or make sure yours hasn't come loose, I would.
Jun 27, 2010 | Office Equipment & Supplies
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
Shredder keeps running after paper is inserted and shredded
Look if the input sensor is not stuck.
It can be a small "tongue" that tilts when the paper is inserted - some small piece of paper might block it from coming back to original position.
Another type of sensor is an optical one - inspect the feed area for any dust or paper particles. A good blow with compressed air might help.
Oct 28, 2009 | OfficeMax 0M96431 Shredder
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Feb 07, 2008 | Techko SH1524CP Shredder
Paper will not feed into machine
Most likely the sensor in the insertion area is not recognizing a paper when you try to insert it to be shredded.
Try to clean out the gears, and oil the grinders.
Clean around the insertion area to remove any debris from around the sensor. (Be sure to turn it off/unplug it first!).
If you can remove the shredder head/grinders from the body of the shredder box, turn it upside down and clean it that way as well.
Sometimes the little pieces of paper get clogged up inside the gears.
I got some of the dust spray with the straw...inserted the straw deep into the shredder grinder/gears and sprayed.  I got tons of stuff out.
My motor/grinder worked perfect after I did all this.
Oct 28, 2007 | Royal VF1000MX Shredder
247 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
