Question about Epson Stylus C43SX InkJet Printer
Red light is always on
Im having problem with my printer (epson c43sx) the red light is always on and it indicates out of paper/ink even theres a paper in the feeder and ink in the cartridge...can anyone can figure out whats seems to be the problem? thanks in advance
  • Epson Master
  • 705 Answers
See my answer to your similar question:
t is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Posted on Apr 02, 2008
SOURCE:
PRINTER EPSON STYLUS C43SX
Did you mean paper jam?. If you have used printer for long time, or many pages printed, the paper feeder mecahnic deteoration, especially two rubber in paper feeder. You can replace paper feeder. Or you can repair the rubber by adding tape below rubber to to add thickness of rubber. I have tried and success. Good luck 4 u.
Apr 08, 2009 | Epson Stylus C43SX InkJet Printer
C43sx both lights on
ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
Jun 11, 2008 | Epson Stylus C43SX InkJet Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
The error light on the C43sx is quite "non-descriptive". It simply means there is an error - that error depends upon the flashing/timing of the light.
I suggest you get hold of the Epson service software to get a better idea of the problem. It is quite possible the machine has simply hit the ink overflow protection counter limit, which is easy to fix with the above software. It is also possible the machine has a fatal error in which case the trash bin beckons.
Visit this person for a source of the software and more help.
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Epson c43sx does not print
It is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
change the cartridge thats simple red light indicating you must change your catridge
My printer doesnt work at all
try printing documents in notepad... if it worked then reinstall your printer driver. and make sure you have ink.
Jan 08, 2008 | Epson Stylus C43SX InkJet Printer
If your PC is connecting to it normally (no connection errors), it sounds like you printer is having the service reset hardware problem. Try installing the EPSON reset software and check all counters and error codes.
Try this one which fixed mine:
http://www.ssclg.com/epsone.shtml
Good luck...
Nov 15, 2007 | Epson Stylus C43SX InkJet Printer
Epson c43sx red ligh on
my printer does not print.
i used SSC service utility
it says printer off or some other problem.
what should i do
Aug 13, 2007 | Epson Stylus C43SX InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
