Question about Epson Stylus C43SX InkJet Printer
Epson c43sx current ink levels not shown in the properties
I have epson stylus c43sx. the ink levels on the properties does not show the current levels of my ink cartridge. its as if its not detected what's wrong with it? pls i need help
  • Anonymous Mar 23, 2014
    With Epson Stylus 215 printerI cannot check the level of the ink in the four cartridges as I could on Windows XP. I am now on Windows 8.1
  • Epson Master
  • 691 Answers
See my answer to your similar question:
t is possible that the ink cartridges in your printer (especially applicable if you are using refilled or compatible carts) can not be read by the printer. Some compatible cartridges have a failure rate as high as 30% and so it is very possible that the machine either does not see the cartridges or can not read them.
Replace the cartridges with genuine Epson ones and try again. The genuine ink will also help to clear any hardening cheap ink in the print head.
Posted on Apr 02, 2008
How to read ink levels in an epson nx110
All Epson printers (well, the ink ones) have a small utility built-in called the STATUS MONITOR. If you click on the MAINTENANCE tabbed page in the Properties, you can start this just by clicking on the item. It will show the ink levels. Normally, this status monitor should start up whenever you print - with an option to show the ink levels, as they do not auto appear when printing, compared to the option shown above. Note that the monitor does NOT actually shown the real ink levels as the chips on the cartridges and the internal electronics within the printer simply work on the number of prints made - so often when showing empty - there will in fact be ink left unused inside the cartridges. For this reason alone, worth your while getting some refillable cartridges and bulk ink (normally in 100ml bottles - so you would get equivalent about 10+ refills and save lots of hard earned dosh!) but you would also need an inexpensive chip resetter. My advice is get the refillables with ink (most compatible inks are as good as - some better - than Epson's own expensive original cartridge inks) and when one cartridge shows requires replacing, you remove all the cartridges, fill them all, reset the chips and replace - that way you show all as full and on ly have one cleaning cycle - thus also saving lots of ink normally wasted when replacing one cartridge - each requiring a cleaning cycle and loss of other inks. I have no idea where in the World you live so cannot recommend a supplier - just use ebay.com or amazon.com to find suitable suppliers convenient to yourself.
May 29, 2014 | Epson Stylus Multifunction Inkjet Printer/...
Ink indicator lights
It's mean "ink out". Not actually "inK", but ink level counter reached zero. If using original ink tank, just replace with new one. If using "hardware resetter", reset ink level counter. If using CIS ink tank, it will be auto reset.
Remember, it's program not actual ink. So, if you reset it, ink level will show full, even if you didn't refill ink tank.
Oct 01, 2013 | Epson Stylus C43SX InkJet Printer
When using my mac I can't see supply levels so I don't know which cartridge I need to replace
usually if you go to your devices where the epson stylus is shown in control panel or whatever for mac's there choose something similar to properties I would guess there is a box that can be checked that would allow to show ink levels.
Mar 20, 2011 | Epson Stylus Photo R220 InkJet Printer
Print out of my epson printer c43sx is blurred
Two things check the ink or go to the manufacture's website and download the latest driver.
Apr 08, 2009 | Epson Stylus C43SX InkJet Printer
Printer service is over
This usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Mar 30, 2009 | Epson Stylus C43SX InkJet Printer
Shows replaced cartridge as empty
The cartridge chip needs to be reset to "full"; for this you need a chip resetter - this should have been done by whoever refilled the cartridge for you. You can get your own Epson chip resetter very cheaply on E-Bay.
Please rate this solution if it is of use to you
Feb 21, 2009 | Epson Stylus C43SX InkJet Printer
Ink
Apr 02, 2008 | Epson Stylus C43SX InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
418 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
