Question about Bosch 24 in. SHU43 Built-in Dishwasher
SHU43 running constantly
We've never had a problem w/ our dishwasher until tonight. I started it and left the room for a while and came back because I smelled something like burning plastic... or overheated motor. The display on the dishwasher still said 92 minutes even though it normally starts at 100 minutes and it had been well over an hour. It appears that the washer is stuck in the very first stage where it drains any left over water in the bottom. I think its just continuing to try and drain even though there is very little water there. I added a gallon of water to the bottom and started it over again to see if there was a clog, but it drained just fine and never seemed to move to that next stage. Any suggestions would be greatly appreciated.
  • sandyv Apr 05, 2008
    I turned on our dishwasher and two hours later, it was still running and we can't get it out of the Rinse/Dry cycle - we've checked filters, etc.. and whenever we try to start it again, it starts out in the Rinse/Dry cycle and just continues to run and run and run and never finishes. HELP!!!!!!
Had the same problem. The float switch was stuck in the filled position. Removed left side panel to reveal fill and flood safety mechanism. Inspection revealed sludge ( soap scum?) caused float to stick in flood/full position. The drain pump just kept trying to empty sump and no water came. Dis-assembled float assembly, cleaned out sludge, re-assembled unit and let her rip.
Posted on Nov 01, 2008
    Problem Solver:
  • 8 Answers
Intrrnal leak into base of appliance will make drain pump run constantly.
If appliance fills then dumps water with drain punp then keeps filling/draining sequence then the flow meter could de faulty.
Call in engineer.
Paul Winn Appliance Services (Cumbria)
Posted on Apr 25, 2008
Lots of Dishwasher Issues- I have a Bosch dishwasher that is approximately 1 year old. For the first 6-9 months it cleaned perfect. It would wash everything off the dishes and leave them sparkling clean...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Some of the dishwashing soap is left and the dishes have particles stuck on them especially glasses
Thanks for using FixYa.com! This sure sounds to me like a temperature issue or a recirculation issue. The first thing I would recommend is removing the filter from the base of the dishwasher (inside the tub), 1/4 turn and it comes out. Clean the filter and the area under the large square mesh filter really good. After that, make sure you run the water at the sink until hot before starting dishwasher. If unit still not washing well and runs for a very long time, I would inspect the control for a burn mark on the heater relay which is very common on Bosch dishwashers. Start with the filter first, though.
Sep 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Shu43 built in dishwasher
Running the hot water in the sink until you get the water hot then, make shore you are using jet dry. Bosh dishwasher dry with condensation. Let me know
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shu43
sounds like your impeller/motor is going bad or something is stuck in that area.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
518 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
