Question about Akai PT46DL10 46" HDTV-Ready Television
SCREEN WILL NOT COME ON
START UP GOOD, GREEN LIGHT COMES ON, AND STAYS ON. SCREEN WILL NOT SHOW UP. STARTED WITH JUST ONE OR TWO TIMES AFTER SHUTTING DOWN FOR A FEW HOURS. PROGRESSED TO FIVE AND TEN TIMES, THEN TWENTY TIMES TRYING TO START. SEE BULP LIGHT UP THEN GO OFF. SOMETIMES THE LIGHT BULP STAYS ON BUT STILL NOT ABLE TO GET SCREEN TO COME UP.??
REPLACED BULB 8 MONTHS AGO WITH NO PROB. CHECKED BACK DOOR SAFETY SWITCH, WORKS FINE? CLEANED FILTERS CHECKED FANS AND WIRES FOR GOOD CONNECTIONS ALL OK.? ANY BODY HAVE A CLUE??
  • SDF2691 Apr 10, 2008
    OK NOW I DO NO EVEN HAVE ANY POWER . NO GREEN LIGHT NO SCREEN AND I CAN HEAR THE ELECTRICITY RUNNING INTO THE TRANSFORMER WITH A BUZZING SOUND, BUT STILL NO START UP..???
  • Lacey Lane
    Lacey Lane May 11, 2009
    No power, no lights, no signal...... moved the set and now it doesn't function. Tested other sets to ensure power and signal strength. Rrrrrrr.
  • 5 Answers
Could be a few things. Bad bulb? Just like anything, some are just not made correctly. Could be the ballast that powers the light, or you may have a component on any board that is failing causing it to go into a protection mode.
Posted on Apr 05, 2008
SOURCE:
I can't get my tv to turn on. I turn it on and the green light comes on 3 times and the light only stays on for 3 seconds and then turns off. Can't get anything to happen with screen. Can you help me
Does it sound like it's coming on then powers down? Mine turned out to be the bulb. I bought a bulb on Ebay for less than $90.00 and installed it myself.
The bulb was inside a square metal housing, pull housing and bulb out of tv, replace the bulb reusing the existing housing, then replace..... Pretty easy fix, and I'm not all that mechanically inclined. Good luck!
Apr 05, 2013 | Televison & Video
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
Grand Wega turns off and comes back on
sounds like your lamp is getting weak, you need to replace it.
Jan 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
[email protected]
Jul 18, 2008 | RCA HD52W58 52" TV
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
PS2 Slimline Dies
did you try cleaning the ps2 take it apart and clean it
Jan 14, 2008 | Sony PlayStation 2 (PS2) Compact System...
Screen shows green and lines and shuts off
if the screen gets really bright then shuts off its going into protection shutdown. Could be a bad or shorted green tube. Or your missing the drive voltage from the sweep supply that suppys b+ to the screen transistors or the High voltage block. This is a hard thing to track down without monitoring points in the curcuit. If you troubleshot electronics i would start with measureing the screen voltage first. If thats ok then i would then monitor the HV shutdown triger point to see if the problem lies from the HV going to high and if its shutting down from an overload then test the green crt. if thats good disconnect the green 2nd anode lead from the HV distribution block to see if its in the green tube or from the High voltage. Any way your gonna need a service manual and a schematic and you can order that from sams photo fact.com ood Luck
Apr 29, 2006 | Sony KP-53V80 53" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
135 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
