Question about Toshiba Tecra 8100 Notebook
Upside down screen
My laptop had water spilt on it.. but didnt realise until i went to i had close the lap top and held it on the side.. and water dripped out.. now my screen is upside down.. can u help before i take it in to get repaired??
    Genius:
  • 2,785 Answers
Dear itzaleesh
plz try the following steps
right click on open space in your desktop -click on properties-click on display properties - click on settings -click on advance(below right near troubleshooting tab)-a dialog box of your graphic card propeties will open-click on graphic properties-click on display settings-you will see rotation-in rotation the degree should be 0 if it is not then you make it 0.then click on apply and click ok.
report your findings back
Posted on Apr 02, 2008
Which water pump bolts go where on rodeo 3.2 v6?
Put the bolts in until they all have the same length sticking out before tightening, that is how they go.
Oct 18, 2012 | 1997 Isuzu Rodeo
My Sony Lap top model PCG 3G7P was accidentaly fall on the water and it wont start anymore. Can I still fix the laptop and recover the data in the hard disc. What parts in the lap top are usually damaged...
Remove the battery from the laptop
leave in a dry room on its side and leave overnight.
let the water drain out and dry out then try switching it on.
if you get lot of beeping then the keyboard has failed (which can be replaced.)
If you get no lights or sound coming from your laptop hen it probably has died
Jul 23, 2011 | Computers & Internet
Spilt drink on inspiron 1720. after letting dry
Make sure you DO NOT plug in your lap top to the power out let. This could cause a shock.
You see the Dell media direct, means your CMOS is OK.
But if Windows is not loading means the spill could have damaged your hard drive. I would strongly suggest you take it to a shop where they repair laptops.
This way you may have to replace your hard drive, but save your note book.
Jun 25, 2010 | Dell Inspiron 1720 17" Widescreen...
Had laptop sitting in lap and turned body briefly lap top went off and will not power up. the fan runs but will not power up. screen is blank
you may have hit the sleep or standby button. Try turning the pc off by holding down the power button untill you hear the fans stop. then power up as usual.
Nov 08, 2009 | Toshiba Satellite M35X-S111 Notebook
Water was poured on the laptop
Ouch, you really should pull the battery and disassemble the laptop and dry the component ASAP. Water is really bad for your laptop. You didn't list the model, so can't help you with the disassembling instruction, but in general, the disassembling starts with the top.
Oct 04, 2009 | Acer Computers & Internet
Water dripping into refrigerator from cooling area
Your defrost drain in the freezer is frozen closed.
Turn the fridge off.
Remove the rear freezer panel.
Remove the visible ice.
Use a hair dryer to thaw the drain hole in the back of the freezer in the center of the drain trough.
Mar 12, 2009 | Refrigerators
Lap top will not start up
take it to service center before you try anything else and the problem gets worst
Nov 22, 2008 | Lenovo 3000 N200 Notebook
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Cleaning case of laptop
yaa any chemical might hurt you lap-top case.
Just use dry cotton cloth or light dumpped with clean water.
Thanks
Iqbal
Apr 26, 2008 | Toshiba Satellite A105 Notebook
Water dispenser dripping
Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
Feb 16, 2007 | Kenmore 53582 / 53584 Side by Side...
Toshiba Tecra 8100 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
