Question about Kenwood DNX7100 Car Video Player
Kenwood DNX7100 no sound when vehicle is started
I have a '06 Dodge Ram with the factory Infinity sound system. Since installing my new head unit about 1 out of 3 times that I get into my truck and start it, there is no sound coming from the truck speakers. I do have a sub in the rear that sound does come from, but none of the door or dash speakers have any sound. I can turn the unit off and then back on, but still no sound. The only way I can fix it is to turn the key off and back on. This is getting old. Any help on fixing this problem would be greatly appreciated, thanks.
  • bobalex1321 Feb 12, 2009
    i have the same kind of thing with my 05 f350 sound from the sub but nothing from the doors and they are infinity 682.9cf everything worked good for about 10,000 miles then this happen maybe loose wire or HU but iam looking to find it KAPPA682.9CF
'06 and up dodge rams have a CANBUS system, you have to buy an $80 adapter for it to function correctly. Just google "CANBUS adapter".
Posted on Apr 15, 2008
How much torque for each head bolt in a 2004 Dodge ram 1500 3.7 liter
Install the cylinder heads. Use new gaskets and tighten the bolts, in sequence, as follows:
  1. Step 1: Bolts 1-8 to 20 ft. lbs. (27 Nm)
  2. Step 2: Bolts 1-10 verify torque without loosening
  3. Step 3: Bolts 9-12 to 10 ft. lbs. (14 Nm)
  4. Step 4: Bolts 1-8 plus 1 / 4 (90 degree) turn
  5. Step 5: Bolts 9-12 to 19 ft. lbs. (26 Nm)
Dec 10, 2015 | Dodge Cars & Trucks
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
Hi, i have a 2004 dodge ram 1500 with the infinity stereo system. The factory cd player broke and i tried to install a new cd player, i bought the right wiring harrness and conected it. But the speakers...
it sounds like you need to turn on our amplifier. this is simple and easy to do just by connecting the blue/white wire off of the back of the radio to the blue wire on the harness that connects to the factory harness.
Jul 02, 2011 | Car Audio & Video
What kind of wire do I need to install Infinity reference series 605cs with a JL Audio 10" sub and a Alpine Flex 2 amp? Can I use my factory head unit?
You can use the factory speaker wiring for the Infinity speakers you should purchase a amp kit which will give you everything to install the amp. See site below
http://www.sonicelectronix.com/item_18428_Raptor+ISPKBL4-BG+by+Metra.html
Well that all depends on the current audio system you have now is it just a basic or a premium factory system with a factory amp. Honestly you would get a better and cleaner sound if you change the factory head unit to a after market one which has preamp feeds and the higher the preout volt the better. Just make sure it is compatible with the amp volts input (Example 4v to 250mv) If you use the factory headunit you would have to by a high to preout adapter it connects to the exsiting radios speaker leads, but like I said before change the head unit you won't be sorry. Do not forget if you change the radio you need a radio install kit and the wiring harrness which converts the two radio plugs so you don't cut them so down the road you can remove the after market radio and just replug the factory right back in.
Apr 16, 2010 | Infinity Reference REF 605CS Car Component...
05 dodge ram with infinity system amp turn?
There is two ways you can do this you can find the turn on wire for the amp and hook it up to the amp turn on wire from the radio (this is the bootleg way and sound might cutout when you turn the radio up)
The best way to go is to go to best buy or your local sound shop and get a bypass harness for a dodge infinity system(go this way so you won't have rny problems)
Aug 08, 2009 | Sony XR-C9100 CD Changer
2004 Dodge Ram 1500, Infinity sound system. CD/AM/FM not working.
You most likely need a new radio. They go bad all the time in the Chrysler/Dodge/Jeep. Don't know how many of them I have replaced.
Jun 18, 2009 | 2004 Dodge Ram 1500
I have a 1994 dodge ram 1500 with the infinity premium sound in it, the previous head unit i had a was a clarion and it work excellent. I installed the avh-p5700dvd and now i only get sound out of the...
With the Infinity system you need to power up the factory amplifiers. This is done with the blue with a white stripe wire from the deck to the amp turn on lead from the factory harness. Not sure the color of the wire but that's most certainly your problem. If you have a factory to aftermarket wiring adapter it'll be the blue wire.
Oct 09, 2008 | Pioneer Car Audio & Video
Kenwood DNX7100 Car Video Player Logo
204 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
