Broken hinge on laptop
I dropped my laptop and cracked the housing at the hinge. The display side is what is affected. The computer itself was not damaged. Is it possible to have it replaced. I don't think it will hold to try to glue it.
  • iamjiwjr Jun 29, 2008
    I opened my Averatec AV7170 yesterday and the hinge broke. I'm under warranty but I figure it's not covered.
    Am I looking at having to replace the whole laptop?
    Problem Solver:
  • 8 Answers
These are usually sold as a whole from the manufacturer with the monitor attached. If the display is cracked, this is what you want anyway, but if not, you will have to call customer support and try to get just the plastic housing.
Or see if there is a third party who sells them in either stock configuration or graphics if you prefer.
Posted on Apr 02, 2008
SOURCE:
Mu laptop hinges are broken. I wanted to know what problems this may cause? Sometimes when I tipe words, it doesn't work in the screen. This could be related with the broken hinges?
Laptop hinges are generally made of low-cost metal alloys, or "pot metal yeah this may cause problem you can fix your broken hinges easily by spending little time ." Pot metal is not particularly durable, and over the course of a laptop's life cycle, repeated opening and closing of the computer's lid can cause wear that prevents the lid from staying in an open position. Hinges can also wear to the point that they break at the point of attachment, either on the lid or the computer's body.
Hinges are usually attached to the computer's frame via machine screws. In order to get the most life out of your computer's hinges, it is not a bad idea to perform a yearly inspection. Remove the hinge covers and check that the machine screws that secure the hinges are tightened fully. If screws are missing, contact the computer's manufacturer to order replacement screws; hinges missing screws are subjected to additional stress and can wear out faster if steps are not taken to replace the screw.
Lubrication of the hinge is possible, but not recommended; if the wrong type of lubricant is used, it could damage the computer's case or seep into the electrical components and further damage the computer. Consult a professional technician if you feel that your hinges require lubrication.
o Hinges can also be damaged when the computer is picked up by its lid, dropped from various heights or opened beyond the angle at which it should stop. In these situations, damage to the hinges may be of secondary concern, as component damage and data loss might have occurred. Depending on the amount of damage and warranty status, the computer may require complete replacement.
Laptop hinges are not indestructible, but their coverings and trim may show wear long before the hinges are actually in any danger of failure. Most laptops on the market include plastic hinge covers. The hinge covers can develop stress fractures from repeated wear; most of the time, this is not indicative of a hinge problem.
Some laptop hinges are housed within the bezel or trim of the computer's monitor or body. This, too, is generally made of plastic, and might develop stress cracks after a few years of use. Hinge covers and bezels are usually modular, and replacements are generally easy to find at low to moderate costs.
Repair
o Hinge problems can be mitigated with adjustments to the hinge's tension or additional hardware installation by the user. Brackets can be installed on the outer case to allow for hinge-like performance, or the screen can be mounted in a fixed position. If the screen is left permanently open, care should be taken to prevent damage to the screen and to prevent dust accumulation in the keyboard.
The lid and screen assembly can also be replaced, if the correct parts can be found. Replacement of the lid and screen can be cost-prohibitive, with parts and labor sometimes exceeding the cost of the computer.
Sep 01, 2011 | Computers & Internet
Hi, my daughter has a dell inspiron 1545 laptop which is about 18 months old. today when she turned it on , apart from a 3/4 inch strip on the left hand side, the screen had a pattern resembling a large...
i think this is fixable, but just professional teachnician from service center can fix it, you just go to service center, and ask for fix that error
Dec 02, 2010 | Dell Inspiron 9100 Notebook
Lcd hinges cracked
The parts you're looking for are called "display panel hinges" You can buy these parts from compaq/hp directly, but personally, I would call, find out the part number and try to find a cheaper place to purchase them. A detailed video on removing the LCD panel completely can be found here. This will show you how to remove the broken hinges, and on the left side of the page, you can select videos that will show you how to do practically everything else. To get your replacement parts go to the compaq website (I couldn't find the part without the serial) or call 1-800-227-8164. There is also a live chat option once you go to the support section of the website. You may be able to rig the display so it works without buying a part, but now that you have the information, it's up to you. I hope this helps!
Jul 14, 2009 | HP Compaq Presario V5201us Notebook
Broken (cracked) right Hinge on HP nc 4000 and Dell D600 Laptops
You can get replacement parts for this laptop, however it can get expensive. At the end of the day, you can use a super glue that is safe to use around electrical parts, but you might be better off just using an external monitor if you don't need to carry your laptop around.
Jun 01, 2009 | HP Computers & Internet
Broken Dell Inspiron 1501 Hinge.......?????
Its the LCD backcover assembly that is cracked.
Here is the part number for it: UW737
I found one from somebodys Ebay store (not mine or anybody I know) for less then $30.00.
http://cgi.ebay.com/Dell-Inspiron-1501-LCD-Display-Back-Cover-UW737-%22B%22---Z_W0QQitemZ310140987025QQcmdZViewItemQQimsxZ20090509?IMSfp=TL090509125007r14975
Hope this helps.
Ben
May 29, 2009 | Dell Inspiron 1501 PC Notebook
Can i fix my broken laptop.
Well, if the display comes on at all, then it must be a loose connection in the wiring. Sometimes this is a simple reseating of the main cable to the mother board which comes down from the display near or around one of the hinges (in most cases). I would suggest, purchasing a cheap external monitor, and plugging it into the rear or video out port if you have one, and switching your display to go to the external monitor, this will work good as a desktop scenario. Otherwise, you need to take it all apart and see if you can find out where the loose connection is, this is no easy task, and should be done by a qualified laptop repair person who has experience.
Mar 22, 2009 | ASUS F3Jp Notebook
Broken Hinges
you have to change your hinges.Plz visit to your nearest service station.
Mar 14, 2009 | HP Pavilion dv6000t Notebook
Laptop crack
Hi msfox,
If your pc is working fine. Then no worries. Just be extra carefully for the crack. You may consider to apply crazy glue to stabalize the crack (if you dont mind the glue cosmetics).
Good luck.
Jul 24, 2008 | Dell Dimension 4600 PC Desktop
Screen is blank unless a flashlight is shown on the screen. Prior to this happening laptop was dropped and the left hinge broke off. Could something else have broken off?
sounds like the backlight system of your screen is broken. You may have to take it to a laptop repair shop, preferably an authorized service center to have it fixed
May 02, 2008 | Computers & Internet
Toshiba Satellite 2450
It sounds like the hinge itself is broken. I have a relative with exactly the same problem, her laptop screen became floppy and didnt stay in the upright position. The hinges for the screen are complicated in that they appear to come as a top/bottom part already joined together, and need to be replaced as such. The metal used for the hinges is really flimy and easily snaps. this sounds like what has happened to yours. The problem is that is appears to be not econimcally viable to repair, and your probably better off scrapping it or buying another with say;.. a cracked screen and doing a swap-over of parts to get one fully working one (thats what I did)
Feb 25, 2008 | Toshiba Satellite 2450-401 Notebook
Open Questions:
Computers & Internet Logo
614 people viewed this question
Ekse
Marvin
Marvin
