Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
High Definition Projection TV
I left my tv working for 5 days straight when I was out of town, came home and turned it off, when I turned it on again, I did not get any picture on the screen. Sound was ok. Tv will turn off in 1-2 minutes on its own. I noticed that the standby light on tv pannel was blinking for 10 times and sometimes for 5. what part do I need to buy, also how can I fix it
  • 2 more comments
  • Anonymous Sep 10, 2008
    will not come on and am getting 10 lashes. some times it will come on after several hours
  • tmabelitini Sep 22, 2008
    same problem,turn power on, clicks, sound comes on, no picture. then, about 15 sec starts blinking red 10 times, shuts the sound off & keeeps blinking 10 times,pause & starts all over again blinking 10
  • rynorok Oct 03, 2008
    I have exactly the same problem...it started out only happening every 10 minutes and now has progressed to turning itself on and off every 2 minutes...the light blinks 5 times...is there something I can do or does it need a new part?
  • Anonymous Oct 07, 2008
    I have a KDP-51WS550 that does the same thing. The LED blinks 10 times. I have replaced the parts the service manual says to replace (Q8013,Q8014, IC80050) and still the same. please help. Sometimes it comes on and when it does it works great until I turn it off and on agagin then it goes back to the 10 blinks. Please help
    Thanks
  • 4 Answers
The flashes are a diagnostic. It should be only one flash pattern, either a 5 or a 10 (there are several other patterns in between as well). Please verify the number of flashes after power on, several times, and post back here, and I will be able to help with the fix. Based on your initial description, it my be the HV distribution.
Posted on Jul 28, 2008
  • Tdevaney3 May 21, 2011
    10 red flashing lights then sound and red light stops, then red light comes back on real fast for 5 flashes
SOURCE:
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
Where do I put my power cord on my haier model40e3500
Haier 40D3500M LED TV Home Entertainment ' Haier US
www.haier.com/us/products/home.../led-tv/40d3500m.shtml
HaierSimple one cable connection for high definition audio and video. MHL enabled. Mobile High Definition Link allows you to connect compatible devices, such as ...
[PDF]OWNER'S MANUAL - Haier
image.haier.com/manual/tv/LEDTV/.../P020111018525755526455.pdf
+/- . In the MENUscreen, these buttons serve as up/down buttons. 5 POWER. Press to turn on and ... Connect cable pr antenna signal to the TV, either directly or ...
LE40D3281 LED TV - Haier
www.haier.com/us/products/home.../led-tv/le40d3281.shtml
Haier 48D3500 LED TV Home Entertainment ' Haier U
Dec 16, 2015 | Haier Heating & Cooling
I have an InFocus Screenplay 61 in. DLP TV. For most of the time, it won't turn on except for the blue buttons on the TV itself. Sometimes, however, the TV would work for a couple of minutes completely...
The tv projection Lamp inside tv now like 1 1/2 or 2 years already?Tv on and in used every day 4 or 5 hours every day?Yes,this problems,the tv projection Lamp live are ending.Replacement of the tv projection Lamp,tv will work again.
Jun 07, 2011 | InFocus ScreenPlay 61" Rear Projection...
Is my Zenith TV HD compatable?
i dont think so your model number say thats not an hd tv the maximum resolution is the same as a normal tv so mean 4:3 format.....
if you got a warped picture thats mean you youu have an sync problem or so that is difficult to
say from here..
have a nice day,hoping that will hell you
Mar 29, 2010 | Zenith B50M88W 50" Rear Projection...
How to connect blue ray disc player to rca rear projection tv
Unfortunately, there are a couple potential problems. First of all, if you RCA rear projection tv is fairly old and is not a High Definition tv, you may not have an hdmi, dvi, or component connector cables inputs. Without these, you are left connecting your blu-ray only by the standard yellow (video), along with the audio (red and white) rca cables... either way, the High Definition portion of the blu-ray won't work with a non-High Definition tv. It may be time to buy an HD capable tv to use your blu-ray effectively...
Dec 29, 2008 | Televison & Video
High definition
Have you tried Video input #5?
Sep 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
14 MONTH OLD TOSHIBA TURNS OFF BY ITSELF
I repair a lot of these and a average tv lasts like 3 years . It is not like the old days. I suspect the lamp or fans or therm protector.
I would call a local tv shop see what they charge for estimate it might be worth his estimate to find out what it is.
Thanks doctor video
May 27, 2008 | Toshiba 52HM95 52" HDTV Projection...
Will this tv run in high definition?
High definition comes in a few different formats. For your Sony TV the high definition format you can use is COMPONENT VIDEO INPUT (Y/PB/PR).
C-Dog
Feb 10, 2008 | Sony KP-61V90 61" Rear Projection...
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
