Question about Microsoft Xbox 360 Console
I have ever had this problem before, but I did disconnect the xbox from the cable and unpluged the system to take it down stairs to use it, then back up stairs it went. Tryed to hook it back up, but it would not connect. I did look at the settings and reset them. But nothing... robert loehr [email protected]
  • deityrules Apr 02, 2008
    Is this not that new of a concern on disconnects with Xbox 360?
    But what now...............
    Sergeant:
    Champion:
  • 427 Answers
Try power cycling your router.
Then go to your xbox and restore factory defaults
Then go and logg on to your wireless network and check the connection.
For further assistance, call 18004MYXBOX
Posted on Apr 03, 2008
SOURCE:
When i try to take my Xbox online to download maps for my game it says i need an update downloads update gets to the applying stage and then freezes
  • 1) Turn off your Xbox 360 and physically disconnect it from the internet by either unplugging the ethernet cable or disconnecting the wireless adapter.
  • 2) Turn on your Xbox 360 and sign into your account. You should NOT be connected to Xbox Live.
  • 3) Navigate to the "System" blade and choose the "Memory" option, then select your storage device.
  • 4) Now search. Look through all the system folders then find and delete ALL incomplete content files. You can spot an incomplete file by the yellow exclamation point icon. Remember to delete ALL incomplete files
  • 5) Once all the incomplete content files have been deleted, turn off your Xbox 360.
  • 6) Reconnect your Xbox 360 to the internet by plugging back in the ethernet cable or wireless adapter.
  • 7) Turn on your Xbox 360, connect to Xbox Live and hopefully your problem is solved.
Jul 06, 2011 | Microsoft Xbox 360 Console
Tip
How to create a Xbox live ID
<ol> <li><br /> <p>With your xbox turned off unplug the ethernet cable from the back of your Xbox.Next unplug the xbox 360 power cord from the back of the Xbox 360.<br /></li> <li> <p>Unplug ethernet cable<br /> <p> and power cord from the modem. Wait for about 1 minute and then plug ethernet cable back into the modem.Now you need to plug other end of the ethernet cable into the back of the Xbox 360.<br /></li> <li> <p>Plug the modem power cord back into your modem , wait for lights to light up on your modem (this can take up to a minute).The last step is to plug the Xbox power cord into the back of the Xbox, turn it on and you are ready to go<br /></li></ol>
on Dec 06, 2010 | Microsoft Xbox 360 Console
The xbox 360 is plugged into the wireless router down stairs, how will the xbox work upstairs in the bedroom not plugged into the router.
if ur xbox has the wireless adapter it doest need to be plugged in. if you dont have that adapter, you must either buy it and connect wirelessly or purchase a cable long enough to reach the router downstairs
Mar 07, 2011 | Microsoft Xbox 360 Console
I was playing call of duty and it disconnected me and now it says notice,you must have an active network connection to play xbox live or system link matches.how do i fix it?
The problem seems to be a random disconnection from your home network. Try unplugging and replugging your wireless adapter or Ethernet cable. If the problem persists, try enabling and disabling these connections from your Console settings on the Xbox Live Dashboard.
Feb 26, 2011 | Microsoft Xbox 360 Console
Change calander and time
my Xbox, system settings, console settings, clock.
note - you can't change them as long as you are connected to Xbox live. You will have to disconnect or unplug your Ethernet cable.
Feb 08, 2011 | Video Game Consoles & Games
4 rings of death on my xbox. how do i fix that?
Troubleshooting the 4 red light error on the Xbox 360 is relatively simple. The first step is to turn off the console and unplug all peripherals.
Now, check the AV cable connection at the back of the console. Disconnect the cable and reconnect it (listen for the snapping sound). Now, follow the cable to the the termination (usually the TV and/or an entertainment system). While you are following the cable, ensure that it is intact, with no scuffs, cuts, crimps or kinks.
Damaged AV cables can malfunction, causing the console to not recognize that the cable is present. If the cable is cut cleanly, no signal will be sent to the TV. However, if the cable is bent sharply, kinked or crimped, it can create damage over time. Eventually the wire within the cable will weaken and break. However, during that time, the 4 red light error can occur due to a loss of connectivity. Unplug the AV cable from the TV or entertainment system and reconnect it.
Now, turn the console back on. If the 4 red lights have gone out, the situation has been resolved. If the lights remain lit, unplug the AV cable from the back of the console once more. Get a clean, dry cloth and clean the metal portion of the connector. Once you have wiped it thoroughly, reconnect the AV cable/pack to the back of the console.
Finally, if this did not work, substitute a cable that is known to be good for your own. Connect it to the back of the console and the TV/entertainment center as usual. Power on the console and wait to see if the LEDs light up once more. If they do not, you simply need to purchase a new AV cable.
However, if the 4 red lights remain lit, you can still try other options.
Jul 13, 2010 | Microsoft Xbox 360 Console
How to fix flashing dots xbox 360?
It could be the cable port needs resetting. On the TV unplug the tv and on the xbox disconnect the cord and turn off the xbox and unplug it. Then put the different cord on and plug the 360 back in.
Jul 09, 2009 | Microsoft Xbox 360 Console
Cannot play any type of game, receiving E-74 error on screen, "system error" and flashing red light on on/off button
E74. System Error. Contact Xbox Customer Support. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); This behavior occurs when the Xbox 360 console experiences a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Here are some steps that you can use to try to resolve the issue. 1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on. 2. Turn off the console, and then disconnect any accessories that are connected. For example, disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem still occurs. This can help you determine whether the console or an accessory is experiencing the problem. 3. If you continue to experience this problem, contact Xbox Customer Service.
Note If the agent cannot help you resolve this issue, you may have to return the console to Microsoft for repair. If this doesn't work, please click here to talk to an xbox agent who can further assist you with troubleshooting ideas.
http://xbox.agent.asahost.com/
Good luck! :)
loadTOCNode(2, 'moreinformation');
Sep 07, 2008 | Video Game Consoles & Games
E74 system failure... AV cables?
If this doesn't work, call MS and explain all this to them. If they do not offer to fix it for free then you can try repairing it yourself or selling it and getting a new one. If you opt to repair it yourself, let me know and I will give you some advice and resources. Good luck!!
Aug 15, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
