Question about Minolta Dimage Scan Elite 5400 Film Scanner
Dimage 5400 on an Imac
I have just installed the software on an imac.  Whenever I try to start, I get an unknown error problem and I am told to see if any other dimage software is runnint
  • darwin6 Oct 17, 2008
    I get the same error message with OS10.5. But the libnit file isn't in library and there is no Dimage folder in the library
Try deleting a file called MFSLibInit which the scanner sometimes seems to erroneously create when you launch the software. The file will appear in the dimage folder (you'll find that folder in the preferences folder within the library folder). Then re-launch. This solved the problem on my powerbook but I now have a new MacBook pro and am having the same problem and this is not solving it. Good luck.
Posted on May 15, 2008
SOURCE:
I recently got an iMac 27" I5. My first Mac, it
Probably there is no driver for your unit with this version of Mac . It's the same problem with Windows Vista or 7 .
Jan 01, 2011 | Konica Minolta Dimage Scan Elite 5400 II...
Why won't Minolta film Scanner work with iMac and OSX 10.6.2?
Hi
I bought a secondhand, nearly new Minolta Dimage Scan Elite 5400 a few years ago but never tried to use it until now when I tried to get it to work with my iMac running OSX 10.6.2. I uploaded the Dimage software but I cannot get it to recognise the scanner - any suggestions? Do I need to get updated drivers?
Feb 02, 2010 | Konica Minolta Dimage Scan Elite 5400 II...
Computer does not recognize camera in video mode
Get one of the best technical support by calling iMac Technical Support Number 1-833-493-0111 right now. Fixing all the issue like installing and setting up your iMac, fixing the blue screen error, updating BIOS setting and any other issues. Call at our iMac Technical Support Phone Number 1-833-493-0111 and fixes all technical issue instantly with the help of certified and well trained technicians.
We provide services for iMac:
    ·Installing and setting up your iMac
    ·Fixing the blue screen error and other kind of startup error
    ·Optimizing and speeding up the overall performance of your iMac
    ·Providing solutions for OS and browser related problems in your iMac
    ·Spyware removal, malware removal and other kind of virus removal from your iMac
    ·Installing antivirus application to your iMac
    ·In solving any kind of complicated random reboots in your iMac
    ·Restoring your iMac to its original factory settings without losing any kind of data from your device
    ·Automatic scanning for any error in your iMac with the help of the antivirus software
    ·Updating the BIOS setting
    ·Cleaning up the browser cache, cookies and other internet junk files from the device.
    You can get one stop complete solution at reasonable cost with complete safety. So if you need help for iMac for resolving any technical issues, call our toll free iMac Customer Support Number 1-833-493-0111 and get quick response to solve your problem. We also provide support service for all models of Apple Mac computers.
iMac Technical Support Number 1 833 493 0111 iMac Help
1-833-493-0111 imac technical support number-h2qlb1n4qi1rinyfmguza2q4-4-0_0.png
Jan 03, 2010 | Apple iMac G5 Desktop
Konica Minolta DiMAGE Scan Dual IV Film Scanner driver in an IMac
DS Dual 4 even works with SnowLeopard on a CoreDuo MBP. But it doesn not support Autofocus when used under USB2. You have to use a USB1.1 Port, if you want to use autofocus function. Every time the software crashes, because you tried e.g. to use autofocus with USB2, you will have to close the application, go to the folder User/Library/Preferences/DS Dual4/... and look whether there is a file name something like "MFSlib...." and pull it to the trash bin. You can start the application again. PS.: Your keyboard USB port is a USB 1.1 port!
Jul 06, 2009 | Konica Minolta Dimage Scan Dual IV Film...
MINOLTA SCANNER DiMAGE SCAN ELITE 5400 II
My 5400 2 scanner worked well with windows XP but will not start with my new computer WINDOWS VISTA.
ERROR message Can not find scanner, check connection
ERROR message 1 unknown error
The scanner was purchased new 1-2006
my installation dick is for Win. XP Version 1.0.1.
Dec 25, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Can't start up Konica Minolta Elite 5400 II
This problem usually occurs when the scanner software crashes, or the scanner is turned off in operation, or the computer is shut down before you quit the software, etc.
The K-M driver software gets corrupted.
I use mine with a Mac G3 Tower and OS-X v 10.4.9.  What I do is search for all the Konica-Minolta components using OS-X spotlight and then delete them.  After reinstalling the K-M driver software and restarting the mac, the scanner should work fine.
Nov 15, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Minolta Dimage multi pro
Initially, I get a green flashing light when unit turned on, but after a minute or so, it turns to a red flashing light. It will take in the film tray only when blinking red, not when blinking green. My iMac has a hard time seeing the scanner, keep getting "scanner not found" messages. I have to go to system profiler and have it refresh and then it finds it, then the scanner software sees it too. But I have been unable to one preview out of it, says LED error and that's it. Using 10.4.10 on an iMac 20" with 2.5gb of RAM, using Pshop CS2 or going through Minolta Driver of OSX I got off of VersionTracker. I did remove the screw for transport right away. Will feed in 35mm tray with red blinking light, will not feed in 120 tray except partially with red blinking light, and only a couple times out of maybe ten tries.
Aug 23, 2007 | Konica Minolta Dimage Scan Multi PRO Film...
Eject
Delete and re install software to prove that is not the cause them come back
Aug 23, 2007 | Minolta Dimage Scan Elite 5400 Film...
From Import to Scan
Reinstall software and drivers of your scanner. Thank you.
Jun 22, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
Minolta Dimage Scan Elite 5400 Film Scanner Logo
258 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
