Question about Motorola Mobility RAZR V3
Razr v3 wont charge
My razr wont charge and its not the charger because it works with other phones and its not the battery because ive tried using different batteries.
  • MamaJune Apr 03, 2008
    I have a similar problem. My phone recharged the batteries fine for the first few weeks then stopped being able to be recharge the batteries from the regular charger but is still able to recharge batteries from my car charger. The problem is...I'm not in my car that much. I have tried new batteries but have the same problem.
    Novelist:
  • 119 Answers
Dear jayhawk9977,
Since the AC is fine (tested) then the phone is probably faulty at the Mini-USB connector. Please check if there is play at this point as a broken (damaged that is) connector will not perform any function. (Test is as well with your handsfree if any) If there is no audio at this point 99% is the connector.
Surely the pins that are used are not the same for charging/handsfree but you can get an idea if the problem is bigger than thought initially.
Problematic batteries can also lead to non charging. 3.6-3.7V (+0.3V) is nominal voltage that the battery works. (if you have a multimeter please test it as well)
Many regards
Please rate this solution if you found it useful.
Posted on Apr 02, 2008
  • T.M.
    T.M. Apr 02, 2008
    The reason I am telling you to test the battery against a multimeter is to be completely sure, because batteries tend to behave abnormally, not very often though.
Unable to charge
Check the contacts between phone and battery, if necessary align or clean. Are you using original Motorola charger? This solved my problem; I was trying to charge it with one of those "universal" chargers.
Hope this helps!
Apr 08, 2010 | Motorola Mobility RAZR V3
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
Oct 26, 2009 | Motorola Mobility RAZR V3
Racer0ne moto razr v3 battery wont charge when I connect the charger the phone says battery wont accept chage
dirty contacts
clean the plug in contacts
if posable ask a friend to try there charger
Jul 31, 2009 | Motorola Mobility RAZR V3
Razr v3 drained battery charging
the desk top charger wont be working for your device and I suggest you to replace the battery on to another mobile phone and try charging it
Dec 26, 2008 | Motorola Mobility RAZR V3
Motorola V3 RAZR won't charge!!!
hmm well i suppose u try with a new charger 1,, b4 you throw it away
Feb 05, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 won't charge
have you tried measuring the output voltage on the charger?? if not... use a multimeter to check if there is a voltage coming out on the charger.. if there is... you doomed.... the charging module (charging IC) on your phone is fckd..
Jan 11, 2008 | Motorola Mobility RAZR V3
V3 Razr is dead, wont charge
take it to a local cell phone dealer and see what they say. most likley bad charger or bad connections.
Jul 08, 2007 | Motorola Mobility RAZR V3
Phone is dead wont take charge
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
Feb 24, 2007 | Motorola Mobility RAZR V3
Charging problems
umm dat mite be a prob becuz the car usually pumps more voltage in the fone...........and if too much is pumped it damage the circuit board and mite even fry the system...... be care ful and keep trying the wall charger..........hope it works
Feb 21, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
56 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
