Question about Vacuums
I have a windtunnel vacuum that the brush rolls fine when it is upside down but when I turn it right side up it will not go hardly at all and starts to smell hot.
  • 25 Answers
Replace the belt they wear manufacture reccomends replacement of the belt every 90 days
Posted on Apr 02, 2008
SOURCE:
Changed belt , it broke again not sure why
gotta make sure both ends of brush bar are clean and turn freely
Apr 22, 2015 | Hoover U5753-900 WindTunnel Bagless...
How do I replace the belt for this model
Make sure vacuum is not plugged in to power outlet. Lay it upside down and remove 4 screws from bottom plate covering brush roll. Remove bottom plate and pull the brush roll out. Clean hair and debris from brush roll and make sure it spins freely. Remove end caps from brush roll if possible and clean debris out. Install new belt around motor shaft then insert brush roll into belt and pull on brush roll to give you enough leverage to stretch belt far enough to put. Brush roll back into position. Reinstall bottom plate and screws. Make sure brush roll will turn before turning vacuum back on. Belt will lose elasticity and should be replaced twice a year.
Jan 17, 2015 | Hoover U5434-900 WindTunnel Plus Bagged...
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
Is it necessary to take the vacuum cleaner apart to change the belt on a Hoover Wind Tunnel Self Propelled vacuum cleaner, model UI6460-900? If so, how is that done? If not, how do you get the belt on...
To change the belts, make sure the vacuum is not plugged in. Lay it upside down and remove the screws holding the bottom plate on. Remove the bottom plate, pull the brush roll out noting how the belt goes so you will know how to put it back together. Especially how it goes around the idler pulley. Remove both belts, replace both belts, install the V belt onto the transmission first then around the brush roll and put the brush roll in place. Install the flat belt around the motor shaft and then onto the transmission pulley.
Feb 06, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Changing the belt
Always make sure your machine is unplugged from the outlet before replacing the belt.
Newer Oreck uprights have an access plate on the right hand side of the base (as you're looking at it from the front). Remove the one screw from the access plate and slide it forward. Snake the new belt around the brush roll pulley and then strrrrrrretch it back to the motor shaft. Replace the access plate.
If your model does not have an access plate; turn the machine upside down, Remove all screws. Lift the bottom plate off. Observe the position of the brush roll ends, One side of each end cap will have several notches cut into it,this is the 'new' side, the other side is smooth, this is the 'old' side. You can reposition the brush roll the the 'old' side if your bristles appear worn down.
With the brush roll still removed; place one end of the belt over the motor shaft first, place the other side of the belt around the brush roll pulley and stretch the brush roll forward until it is back in place.
Spin the brush roll by hand before replacing the cover to ensure the belt is not pinched.
Replace to cover.
May 16, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Brush won't turn
The belt may look ok, but if it is more then a few months old, then it has stretched to where it won't turn under load, just slips. If it is very tight feeling, then check down where the pulleys are, the V belt has a black roll that maybe jammed and not pushing against the V belt when the handle is in the down position.
Sep 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belts
yes you can. belt goes round the brush roll and is in view. also turn on and see if the brush roll rotates. if belt is broken then no rotation
Sep 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush Roll won't switch positions
The adjustment knob on the hood of the machine is a plastic "arm" that prevents the belt tensioner from tightening up the v-belt so that the roller will stop or start. If the knob is adjusted while the handle is back, it can break the plastic arm off and then the function will not work. This knob should only be adjusted with the handle in the upright position. Usually, if the arm is broken, the roller will still turn when the handle is lowered and will not turn off when the knob is selected to the bare floor. If the brush roll will not switch on , it is usually a problem with the belt(s). You should replace the belts yearly. They can look fine, but be worn out.
Dec 14, 2007 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
496 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
