Question about Denon AVR-2802
Also problem with Denon AVR-2802
I also have a problem with the Denon AVR-2802. Worked fine in 5 years. This spring some of the channels started to drop out, and I returned it for repair. The terminals was soldered by the repairshop and it seemed to work fine after this repair. Now no sound is produced from the speakers (both in playback with tuner, dvd, cd-player and in the channel level configuration). If I just turn the reciever on in very high volume (-05) i could hear a very weak output in the speakers, almost as if the amplifier doesent add any amplification to the signal. Odd that so many on the web has this excact problems with the AVR-2802 after 4-5 years. no sound look like muting is press
Had same issue with an older Denon receiver.
The problem: "Tape A" was activated.
Pressing the "Tape A" button to deactivate the function solved my issue :-)
Posted on Jul 05, 2015
  • 871 Answers
Check back with that technician. have him check what he did. if you do see similar cases on the net. what was their solutions?
there may be some parts on the board that may need replacement.
with regards to sweet_rascal and bestdarngood post,
the problem lies not on the item itself but in the standard operation of the item which is already years. try to follow bestdarngoods post and see if it will work.
thanks for using fixya.
Posted on Apr 02, 2008
  • 3,037 Answers
In general, you should try resetting the microprocessor on any Denon receiver if/when you notice a problem especially when it may seem rather odd. (no obvious defects, while not operating properly)
Resetting procedure is similiar between the models; On units WithOut the Master On/OFF button; Unplug the power & while pressing both speaker A&B buttons simultaneously, plug in the main power cord. Youll notice the entire display would start flashing as long as A&B is held on---allow it to flash 3-5 times & release them. Unit is now reset to factory presets.
If resetting did not have an effect, then problem is more likely in volume control IC or it could even be the processor itself.
Let me know how this works out. Thanks and good luck
  • Benjamin Patri
    Benjamin Patri Apr 05, 2008
    have you tried to solve your problem?
  • Benjamin Patri
    Benjamin Patri Apr 10, 2008
    have you been able to fix your problem, if you have let us know and please rate a solution as fixed, thank you and have a good day
    Guru:
  • 1,894 Answers
Its just the amplifier problem
  • dewan nafees ahmed Apr 02, 2008
    oh.. nice.. thanks for that early..
    yes bestdarngoods and early can be tried
I want to know if there is anyway to play music from my ipod touch 2cnd generation with my Denon AVR 2802 Home Theater System.
mini 3.5mm to rca adapter is very simple adapter available most anywhere its headphone to red-white and works very well and only cost 5$ or so ok:)
Jun 03, 2011 | Denon AVR-2802
I have denon avr-2802.. suddenly no sounds will come out but the power ok.. help me pls..
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2802-Receivers-manual/id/363bh830/t/2/
Is it silent for ALL inputs including the Test Tones?
Page 33
Function incorrect, Muting, Tape or EXT Input on when it shouldn
Feb 19, 2011 | Denon AVR-2802
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
Denon 2802 amp
Dear Armani,
You cannot put de leads from an MP3 player or your TV into the pre-amplified connection of your Denon,
the phono "stage" is a low input stage, your input from MP3, TV, CD, DVD oscasetteplayer is high output (a 5 to 10 times stronger signal)
Try every other stage like tape 1 or 2, this will work just fine,
succes
Apr 30, 2009 | Denon AVR-2802
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Denon 2902 No Sound
REPLACE MUTING TRANSISTORS IN DSP PANEL
Sep 04, 2007 | Denon AVR-2802
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
Jul 22, 2007 | Denon AVR-2802
Denon AVR-2802 Logo
556 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
