Question about Dell Inspiron 6000 Notebook
Cursor jumps erratically
When I'm typing a document (letter, memo, email etc) the cursor will suddenly move up several lines and continue with my input there. Very. Frust-Rating. Is it anything to do with my touchpad (which I NEVER use?)
  • 1 more comment
  • Alan DM
    Alan DM Apr 02, 2008
    If that is indeed what is happening, is there a technique to prevent it? Why is the touchpad
    a) so huge?
    b) at the bottom of the panel?
    c) enabled all the time?
    Thanks SallieJohns, and good luck to you, mate.
  • Anonymous Apr 06, 2008
    I have exactly the same problem with a inpirion 6000 and it is totally irratic ... nothing to do with the touch pad or mouse .... it seems to be a problem associated most commonly with Word.
  • Anonymous Nov 17, 2008
    I have the same problem with Latitude D630 ATG.
Mine jump to where the cursor is positioned or close by. Its a PAIN
Posted on Jul 29, 2008
I have the same problem...it is totally irratic, and is not in association to the cursor. it jumps back into the text, or in word up to previous lines.
Mine is definitely not a touch pad issue.
Posted on Apr 06, 2008
    Problem Solver:
  • 8 Answers
Most likely, your wrist is gently touching the touchpad, and your computer is interpreting it as a 'tap,' and it so happens your cursor was located several lines up.
Or if you use a separate mouse, is it on a wood or uneven surface? This will cause it to jump up those few lines and again, your wrist (or if you have big hands like I do, the bottom of your thumbs) will tap it.
Posted on Apr 02, 2008
  • SallieJohns
    SallieJohns Apr 02, 2008
    If you use an external mouse, you can disable the touchpad in the device manager.
How do you stop the cursor from jumping on an elitebook folio 9470m
go to control panel / mouse to open the mouse properties window. along the top of the window should be several tabs. select the tab for touchpad or maybe advanced properties. this tab allows you to adjust the touch sensitivity of the mousepad, momentum, and other properties. adjusting to make it less sensitive may reduce the tendency of the cursor to jump or move on its own. failing that, go for an external mouse!
Aug 14, 2014 | HP EliteBook Folio 9470m 14in LED...
The cursor jumps from place to place as I type
This is a known issue in microsoft word. There is no fix as of yet but most people are moving their cursor to the bottom right of the screen after they have clicked where they wish to be typing. hope this helps
Dec 02, 2013 | Computers & Internet
Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Jul 01, 2010 | Lenovo 3000 Y410 Laptop
I have an Acer laptop. While typing the cursor suddenly jumps up a couple of lines, or suddenly may highlight a phrase, causing instant erasure of the previously typed material. Why does cursor continually...
your palm might be hitting the touchpad causing your mouse cursor to move and jump around... try to type with only your fingers hitting the keys and the back of your hand raised and not hitting any part of your laptop... hope this helps....
Nov 10, 2009 | Acer Aspire 5315 Notebook
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
When I type my cursor continually jumps around to different lines
Well, you could try this...
Go to Start>Controlpanel>mouse>pointer options. At that page tick "Hide pointer whilw typing"
Hope it works for you:)
May 06, 2009 | Toshiba Computers & Internet
Suddenly the cursor moves back to a previous line and continues typing making a joke of what I'pingm typing (see it just did it)
make sure the mouse cursor is further down the page from where you are typing. If your text continues over the arrow of the cursor and any static electricity or touch is detected by the glide pad of a laptop or S.E. from a mouse it will move the text cursor to where the mouse cursor is.
This is a continual problem with sensitive computers.
sorry there is no permanent "FIX"
Jun 04, 2008 | Computers & Internet
Letter writting problems
Do you use a laptop or some sort of keyboard with a mouse pad? My son used to have that problem when he would type as his thumb would accidentally hit the mouse pad and move the cursor. We solved it in a very low tech way by taping a notecard over the mouse pad when he was using the computer. Depending on the manufacurer, there are ways to turn off the mouse pad while continuing to use a mouse.
Dec 24, 2007 | Microsoft Digit Media Pro bx100005...
Dell Inspiron 6000 Notebook Logo
1,252 people viewed this question
Alun Cox
