Sony PlayStation Portable (PSP) Console Logo
Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Psp not reding games - Sony PlayStation Portable (PSP) Console
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 364 Answers
  • Posted on Aug 22, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
364
Questions
0
Helped
86323
Points
393
This is a problem occurring in all the playstation 3 consoles....... this is mainly because of the poor quality of thedisc,.....as a result it leads to the damage of ur PS3 lens..............usegood original discs........the heating effect is due to the long usage ofpirated discs ...
check your lens if its working good then betterdownload this Repair Guide for further information .........
CLICK HERE to download
Anonymous
Level 3:
President:
  • Master 1,382 Answers
  • Posted on May 19, 2010
Anonymous
Master
Level 3:
President:
Answers
1382
Questions
0
Helped
552352
Points
5097
Try giving the lens a clean with a cotton bud diped in nail varnish remover gently.This should solve your problem. If this fails then i am sorry to say you need to replace the laser unit. It is easily replaceable by buying one on ebay.com for around $15.
Thank you!!
4helpful
2answers
How to download a games and install to psp??
to download a game for the psp
- search for game using bittorrent or any downloading software
- download the game
- save the game on the computer or on a harddrive
to install the game on the psp
- connect the psp to a computer via USB or insert the memory stick on a card reader
- copy the game file from the harddrive to the psp memory card or memory stick pro
- disconnect the psp and try to play the game
note: make sure that the psp is upto date with the firmware because not all games will work right away
if its a PSP GO you just need to go online via WiFi on your PSP GO
- go the sony or psp store then purchase the game download it and save it
How yo download psp games
First, you have to find the game you want, and download it to your computer.
  1. 1 Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  2. 2 To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  3. 3 Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  4. 4 Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
Hopefully, this works for you!
20helpful
3answers
How to downloads games PSP-1001 from PC?
Hello
To download games to your PSP You will download your PSP games from the internet into your PC and then transfer your PSP game files to your PSP using a USB cable. After your computer is connected to your PSP, your PC will recognize your PSP as a detachable memory drive (similar to an external hard drive). It will assign your PSP with a drive letter (usually F: ) which will allow you to drag and drop you PSP games file from your computer's hard drive to your PSP memory stick. Below are some of the steps to download PSP games.
Step 1: You must copy your PSP games file to the correct path or the games simply would not work. The correct path is PSP>GAME (all the folder names are in caps)
Step 2: After the PSP games are fully transferred to your memory stick, disconnect the PSP from your PC. In your PSP main menu, scroll to GAME and then select Memory Stick option. Press X, and list of available games in your memory stick will be displayed. If you find any error on your PSP, you might want to check your firmware version.
Good luck
2helpful
2answers
How do i download free psp go games
Like many others who had purchased original PSP games from the retail outlets, you will realize that as the games is completed, buying new games seem to be getting expensive and unaffordable. What else can I do if I want to continue to play new or old fashioned games on my PSP console? I start search and looking for website that offers free PSP download games.
Once I had downloaded the PSP games onto my console, how to play PSP download games was my next question. I'm not sure exactly how PSP works when I download new PSP games onto the unit, but I sure have found some answers while I was looking for it. Since I'm facing and struggling with this problem on how to play PSP download games on my unit, lots of other people must be also getting the same problem.
Hope that I get this right for everyone to play PSP download games because I used the same method here to play on my console. Before we get started, I'm using a PSP unit with firmware of 1.5 and having a Sony PSP compatible memory stick pro duo.
Since you are going to download the PSP games, you must download the games for the correct version of firmware, if not it will not work. Newer version of the firmware is available to anyone from the PSP official website. Most homebrew PSP games works with firmware 1.5 and below because the newer firmware upgrade is trying to block people from using homebrew games. Make sure the games you are downloading ends with PSP because only PSP files are compatible with Sony PSP unit.
instruction
  • Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  • To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  • Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  • Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
  • 1helpful
    3answers
    How Can I Download PSP Games from the net for free?
    Download Your PSP games from the site give below....U can search your favourite psp in google also...jus go to google and search "Free Psp games rapidshare".
    http://srimeenakshimobiles.com/forums/various-firmware/3242-psp-games-megaupload-links-wanclickid.html">http://srimeenakshimobiles.com/forums/various-firmware/3242-psp-games-megaupload-links-wanclickid.html
    http://srimeenakshimobiles.com/forums/various-firmware/3242-psp-games-megaupload-links-wanclickid.html">http://www.frendz4m.com/forum/showthreads-16-0-2316478+PSP-GAMES-MEGAUPLOAD.htm">http://www.frendz4m.com/forum/showthreads-16-0-2316478+PSP-GAMES-MEGAUPLOAD.htm
    http://www.frendz4m.com/forum/showthreads-16-0-2316478+PSP-GAMES-MEGAUPLOAD.htm">http://www.gameternity.com/download-page/game/psp-iso-cso.html">http://www.gameternity.com/download-page/game/psp-iso-cso.html
    http://www.gameternity.com/download-page/game/psp-iso-cso.html">http://ssubzzero.multiply.com/journal/item/205">http://ssubzzero.multiply.com/journal/item/205
    http://ssubzzero.multiply.com/journal/item/205">http://www.allyoulike.com/category/games/psp/">http://www.allyoulike.com/category/games/psp/
    http://www.allyoulike.com/category/games/psp/">The download links given for these games can be easily downloaded with any downloader...jus like "mipony"you can try this to download your games.here is the download link of that downloader http://mipony.net/">http://mipony.net/
    http://mipony.net/">Thanking you...!!
    4answers
    Games for psp
    download games off the vuze hd network download vuze here
    2helpful
    How to download games to put into PSP?
    go to this site www.pspiso.com you can download games there and some forum or you can use google to search for a psp game or on multiply.com . after downloading game if you download an .iISO or .CSO put it on iso folder on psp ROOT sample e:\iso is your psp drive for PSX game put it on the GAME folder of your psp sample e:\PSP\GAME e: is your psp drive. IMPORTANT! REMINDER: Your PSP must be Custom Firmware to work the game you download NOT the OFFICIAL FIRMWARE ON SONY PSP OOFFICIAL SITE OR UPDATE ON PSP . Thanks hope it could help you out ^_^
    3helpful
    2answers
    I cannot download games on my psp using mininova site
    You need an older model PSP with update 1.54 or below. Downloading PSP games onto your PSP will void your warranty with Sony, since it is illigal and same for downloading PSP games via torrent. The copy protection on newer PSP models, PSP slim and PSP 2000 have extensive copy protection included in their frameware updates so downloading games onto the PSP is near impossible
    2answers
    Ps2 not reding disc
    Try cleaning the lens q-tip and alcohol (not soaking it)
    on the main screen the lil rotating lights if they are not moving you got lens problems
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
