Question about Nintendo DS Console
Almost broken back hinge
Back hinge is broken
  • Anonymous Apr 03, 2008
    it is very frgile and the screebn will come off if i dont hold
    Problem Solver:
  • 6 Answers
This happened with my nds. Try getting a electrician or someone to fix it. That's the only thing that worked for me. I tried even super and model glue. It just doesn't work. If none of the above works, you'll have to live or get a Lite the old ones are pretty fragile.
Posted on Apr 10, 2008
Hgfhgfh
Posted on Apr 07, 2008
Why won't my hinged cupboard door stay closed?
Depends on type of hinge, If it swings back open after you closed it then either the cupboard is not level (old style hinge)...
Or the spring inside hinge is bad/broken and not holding it closed. If the door opens back just a bit (1/2 inch or so) see if hinge has adjustable screws.
Oct 15, 2016 | Top Knobs Hardware & Accessories
Have replaced broken hinge but am stuck getting both fridge and freezer door back on. can do one or the other but not both. westinghouse freestyle fridge/freezer
srack from bottom up- bottom hinge - bottom door- tape door with duck tape- middle hinge- top door- tape top door- top hinge- remove tape- done
May 25, 2011 | Refrigerators
Can't close doc cover properly - seems 'broken' at hinge - can I fix this myself?
The left hinge breaks often enough that Brother changed the part number of the part. I hope that means the new part is stronger; I haven't seen one come back for a second repair. Assuming it's the larger, left hinge that's broken (It always is.), you need an LP2403001 HINGE ASSY L. You can find it from a servicing dealer or online, and it's easy to replace.
Look at the back of the machine and find two large phillips screws in holes. They keep the hinge blocks from coming up all the way out of the machine. Remove both of them and lift the top cover up until it's connected only by its cable. It might take a helper to hold the cover, but you need to unscrew the hinge assy. from the top. The three screws are obvious and easy to reach now that the cover is loose. Put the new hinge on, lower the top back down so the hinges drop into their holes, and put those screws back into the holes in back. You're done.
Jul 11, 2010 | Brother MFC 8820D All-In-One Laser Printer
Can I get parts to replace broken hinge? I have an HP Officejet 6210 All in One.
In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Dec 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hinges for top cover for HP officejet 6210- Q5820A
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
Broken hinge
I'd be frustrated as well. Fortunately, your Inspiron is still under warranty - contact Dell. They may send a tech to fix, or you may need to send back the laptop to them to be fixed.
Jul 30, 2009 | Dell Inspiron 1525 Notebook
How to replace Hinge assembly of Automatic Document Feeder
You can try to get a hinge @ a local authorized brother dealer. I just got mine for 20 bucks, I think that the guy ripped me off, but I needed. Once you get it, it is very easy to replace. 1St, replace the old one by removing the screw in the back of the hinge (back of printer). then pretend that you are lifting the whole automatic feeder up. At this point you will see the right hinge looks likeit it coming out. Don't pull it out completely. Just pull it enough that you can flip the feeder enought so you can uncrew the 3 screw attached to the feeder. Once you remove the broken part, install the new hinge. make sure that you screw hinge first before you slip it down to the bottom hole then screw the hinge to prevent it from moving.
PS: try not to flip the feeder too far back
good luck
Mar 23, 2009 | Brother MFC-8440 All-In-One Laser Printer
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
Nintendo DS Console Logo
44 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
