Question about NEC MobilePro 900c Pocket PC
Cab files I have a used 900c and do not have the original CD's. So I downloaded the cab files from a site that says they are off the original 900c CD but when I copy the files to my device and try to double-click the .cab file I get some "cannot find the file or one of its components". What is up with this...
I found the answer using information in one of the related issues. I installed a custom ROM and all works great now....
Posted on Apr 02, 2008
I have a hp web cam but i am not able to find the cd to reinstall on my computer. I need a download so can install the model no EW192AA
HP offer downloads on their site HP.com. If the Cam came with your PC then check/search in the sys admin files look for cabs - drivers, or the original set up normally retained in any backup arrangement.
Nov 29, 2010 | HP Webcam
MICROSOFT
This may have happened if you use some desktop clean up utillity.
To work around this problem, you have to provide the original installation source files.
For example, use one of the following procedures when you receive the error message:
• Insert the original Office 2003 program CD that you used to install Office 2003, and then click OK.
• Click Browse, locate the Office 2003 program installation folder on the network, and then click OK.
Mar 30, 2008 | Microsoft Office 2003 Basic Edition...
NEC Mobilepro 900c will not connect w/computer
Are you using the NEC Mobilepro 900c drivers? I'm sure the drivers are different. YOu can find the XP drivers here: http://hpcmonex.net/nec900/files/soft/nec/activesyncusb.zip In addition, you should make sure that you have Activesync 3.8 or older. You can find it here: http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Dec 25, 2007 | NEC MobilePro 900c Pocket PC
Dead Mobilepro 900 after bootloader upgrade HELP!
if your 900 or 900c suddenly stops powering up, maybe after a system crash or just on its own after a reboot,
then it probably has a corrupt bootloader image, but otherwise perfectly working hardware.
or if you flashed the device in the wrong way (oops) that resulted in corrupt bootloader...
well, here's the ultimate last chance solution.
what you need:
- PC with windows (98 or later), or linux works too, but this description applies to windows
- if you are on windows, then also cygwin from http://cygwin.com
- parallel port on PC
- jtag cable, schematics for a working example (very simple!!) here: http://hpcmonex.net/nec900/files/jtag/900c_jtag.jpg
note, this emulates a wiggler cable... you can also order some more serious type of wiggler but that costs more.
- soldering iron and the right screwdriver to disassemble the 900c
- bootloader file http://hpcmonex.net/nec900/files/jtag/bootloader410_nolockcheckmsbin_jtagONLY.zip
- jtag tools 0.5.1, here's a version compiled for cygwin: http://hpcmonex.net/nec900/files/jtag/jtag900cfinal.zip
steps:
1. after you got all the above, disassemble the 900c, hpcnec has a disassembly guide here: http://hpcnec.com/cgi-bin/hpcnec.cgi?fid=15&topic_id=1204570453
2. solder the jtag cable to the jtag pins on the 900c like this: in this picture and sort out the LPT end on the PC too.
NOTE: an alternative jtag header and pinout exists on the motherboard, for more information refer to the hpcfactor thread linked at the bottom of this page.
3. now to make the software work... assuming you are on windows, download and install cygwin from http://cygwin.com. when it gets to ask you about which packages to download,
leave all that on default except for an extra package you need, it's ioperm under Devel packages.
4. using cmd.exe, cmd into cygwin\bin and run this command: ioperm -i
5. after that, here is the already compiled jtag tools for cygwin in windows: jtag900cfinal.zip. download and unzip that to cygwin\home\yourusername\jtag. then copy the jtag folder within usr\local\share from jtag900cfinal.zip into cygwin\usr\local\share\jtag now it's all ready...
to start jtag tools, run cygwin from the cygwin icon on desktop or start menu, and from the cmd it opens, issue this command: cd jtag, then issue this command: cd src, finally issue this: ./jtag
6. connect the 900c if you haven't already, and power it up by simply inserting the battery and putting it on AC power as well! type this command: cable parallel 0x378 WIGGLER
(check if your parallel port is indeed on 0x378, in device manager, lpt port, resources) it should say Initializing ...
of course, if you have a non wiggler cable that is supported by jtag tools then use the name of that instead.
7. then type this command: detect
this should tell you your CPU is a PXA255A0.
if it doesn't return anything, make sure the device is on AC properly / battery is fully charged. the point is that the board must be powered on for detect to work.
8. next command is: detectflash
that should return lots of info on the flash
9. now try reading your current bootloader image: readmem 0x0 0x80000 filename
you can check its contents or compare it to saboot.nb0 bootloader image to see if it is the same... if not then it's probably corrupt and you have a good chance to revive the device.
10. now flash the file you extracted from the bootloader download: flashmem msbin saboot.xip
if verification is ok, then you are almost finished now.
11. disconnect from the PC, remove power from 900c, and try reinserting battery and powering up. it should boot up now! if not then maybe something went wrong, try jtag again. note, it's fine if it doesn't boot to OS, just bootloader. you jtagged bootloader 4.10 in, so feel free to just reflash an OS!
troubleshooting:
1. if you had a 900 running hpc2000 OS then the above posted bootloader will not boot the OS. but the solution is simple: you can choose to keep hpc2000 or upgrade to cenet.
if you want hpc2000, then just download and flash this hpc2000 image compatible with cenet bootloader. if you want ce.net then download stock cenet rom from my download page (select any of the options except "Not listed").
then, flash the image from CF card using C+F method (how to described at this link).
2. if cygwin won't run jtag tools then read more for a solution: 1) extract jtag900cfinal.zip somewhere else on your PC outside cygwin folder. 2) take the cygwindlls folder from the extracted jtag900cfinal.zip and copy the dlls from it into \src folder. 3) then copy the jtag folder within usr\local\share from jtag900cfinal.zip into cygwin\usr\local\share\jtag. 4) then, simply (using windows cmd.exe) cmd into the \src folder where you copied the cygwindlls folder contents too and type the command jtag to run jtag tools. hopefully that works.
3. for more information, you can read the original 900c jtag thread at: http://www.hpcfactor.com/forums/forums/thread-view.asp?tid=9529&posts=36
this also describes an alternative pinout for jtag, but as a sumup it is: on the white JTAG connector under the modem: test - 8, nTRST 9, TCK 1, TMS 3, TDI 5, TDO 10, A1-DC3,3V
Sep 23, 2007 | NEC MobilePro 900 Handheld
Upgrade from reader to full function
Yup, softmaker company release a version like word,excel
Sep 21, 2007 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900c softeare
maybe is because processor ou version of windows ce
Aug 22, 2007 | NEC MobilePro 900c Pocket PC
WINDOWS CE PROBLEMS
Perhaps the programs you are trying to install are designed to run on your desktop PC and use activesync to transfer to the PDA..?
Aug 19, 2007 | NEC MobilePro 900c Pocket PC
Device not detected
download the usb drivers
Jul 29, 2007 | NEC MobilePro 900c Pocket PC
Word & Excel programs for NEC 900C
Textmaker http://www.softmaker.de/ might help, I think they have an excel program as well, if not there is one around, you might look on Pocket PC magazines forum there are some 900 users over there.
Sep 15, 2005 | NEC MobilePro 900c Pocket PC
Open Questions:
I WAS TRYING TO INSTALL JLIME ON MY MOBILEPRO 900, EVERYTHING WAS DONE AS PER THE DOCUMENTATION AS PER THE WEBSITE. AFTER ALL THE STRESS OF PARITIONING THE FLASH CARD.. I GOT THE FOLLOWING ERROR.. "ROOT=/DEV/HDA2" NOT found kernel Panic VFS cannot mount I dont understand a bit of this error.. i ahve tried all the zImage files on the website.. but still I am getting the same error. I used the Henchman.tar--------( All the versions avaliable on website" Haret.exe as kernel Bootloader file which read as below # boot a kernel with HaRET # # have the kernel zImage and the Haret executable in the same dir as this file # this file if named 'startup.txt' will automatically launch the kernel when you start Haret # # 'set MTYPE 659' is for the NEC MobilePro900c # # in CMDLINE change 'root=' to point to the location of your root filesystem # eg 'root=/dev/hda1' is the first partition on your CF card # and 'root=/dev/hda2' is the second partition # set KERNEL zImage-2.6.23mp900c set MTYPE 659 set CMDLINE "console=tty0 console=ttyS0,115200n8 root=/dev/hda2" bootlinux i have tried mentioning "hda1" , "sda1","sdb1","sdb2" I believe its not the problem with the Henchman file or is it??? I have the following partitions sdb1 as boot flag which is fat-1GB sdb2 which is of ext2-2GB sdb3 as SWAP-1GB i loaded the boot files in the Fat ie the Haret.exe Zimage and startup.txt file in fat system Please help me out in removing this error and getting Jlime installed in My Nec Mobilepro 900.. I used a transend 4GB flash drive
Jul 16, 2011 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900c Pocket PC Logo
61 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
