Question about RCA F27628 27" TV
PASSWORD OVERWRITE CODE
HI THERE
I have password protected a couple of channels and now i cannot remember the password, how can i overwrite that?
  • 2,337 Answers
If you forgot your password, simultaneously press and hold MENU on the television and volume down on the remote for 3 seconds. Nothing appears on the screen, Parental Controls simply unlock and you can re-enter a password via Lock Parental Controls
Posted on Apr 02, 2008
SOURCE:
Mobicel Metro 2. How can I reset the privacy protection code?
go into settings security the change password will ask you for old 1 then ask you for a new password then it will ask you to confirm password then it should be ok
if you can remember password you will after hard reset the phone
Mar 25, 2015 | cellular Cell Phones
PASS WORD PROBLEM
It is possibly a setting somewhere set when you did the re-tune, causing all of the channels tuned to be protected. try looking through your TV's settings for something that might help. Otherwise, we could really use a brand/model # to help you out any more.
Feb 15, 2014 | Toshiba Televison & Video
I can't get my wii online error code 51330
51330 - Unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Other suggestions:
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this:
    • Unplug both the modem and the router from the power outlet.
    • Wait a few minutes, and plug the modem back in.
    • Wait a couple of minutes for the modem to initialize, then plug in the router.
    • Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response
  • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
If you are still having problems, contact Nintendo and they will help you get to the root of your problem - Nintendo Wii Support
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Sep 13, 2011 | Nintendo Wii Console
Hi, I have a HP Omnibook XT6050 which I can't enter to the BIOS, is password protected. Long time ago someone wrote a password and right now he doesn't remember the password. I tried removing the...
Hi, if you are unable to get the bios master password from HP Support then use http://www.unlockbiosrecovery.com/Unlock_HP-Compaq_Bios.php This bios unlocking service can calculate the bios master password just like HP Support that will delete any current set bios password. For $20 unlockbiosrecovery.com will calculate you bios master password and email it to you within a couple hours and they guarantee it to work or you money is refunded. I use them for all laptop bios master passwords on laptops I repair when the bios is locked with an unknown bios password or unknown hard drive password.
Sep 12, 2011 | Computers & Internet
Hi i forgot password so kindly give to us details how should i recover my data
if you set a password on the folder and cant remember it then, thats bad luck as you wont be able to retrieve it, thats what its there for, to protect files. Next time,put a password you can remember
Apr 14, 2011 | Kakasoft KaKa Folder Protector
Hi. is there any applications to restart my nokia N900...? thank you...
Restore a backup
1 Select > More... > Backup.
2 Select the desired backup and Restore.
3 Select the data types to restore.
4 Confirm that you want to restore the data.
If the backup is password-protected, enter the password,
and select OK.
5 If your device contains a newer version of the files than
the backup you are restoring, the device asks you to
confirm if you want to save the backed up version, or
cancel data restore. Select from the following:
Yes - The device overwrites the current version with
the backed up file.
Yes to all - The device overwrites all conflicting files
without further confirmation.
No - The version on the device is not replaced
hope this helps
John
Jan 22, 2011 | Nokia N900 Smartphone
Dvr will not record. i get the message, " hard drive full" is there a way to erase what is on the hard drive?
You can erase the contents of the drive or set the drive to overwrite when full. Erasing the drive is the equivalent of reformatting (you will not be able to recover the images easily).
To Erase/Format, enter the Menu system and select Hard Drive Setup (seventh line in the list). Press Enter, then go to HDD Format (fourth item in the list) and press Enter. Then enter your password (set up under System Setup) but the default password is 111111, if it is on. If you entered the correct password, the screen will flash HDD Formatted 3 times. Press Menu to exit the menu. (If the incorrect password was put in, Incorrect Password will flash.)
To overwrite, again go to Hard Drive Setup then select the first item, Drive Full. Press Enter to toggle Overwrite On or Off. You will be able to recover the images until they are overwritten.
I hope this helps.
Oct 13, 2010 | CSi Speco Speco Technologies DVR-4CF...
Bios is calling for password for access which is not remembered
Yup it sure will, only if you are doing it at the hardware level. I mean by removing the BIOS battery and all.
May 29, 2010 | Intel Motherboard
RCA F27628 27" TV Logo
138 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
