Question about EliteGroup K8M800-M2 Motherboard
SATA HDD MY bios won't detect a western digital 160GB HDD that i'm trying to install. What should i do?
  • maverickcrui Apr 03, 2008
    I updated my bios to the latest version already and still itdoesn't detect. tried the drive on a few other boards and it comes up without a problem.
  • moremaxtram Nov 19, 2008
    Me too! The WD 160GB locks-up the bios. I couldn't find the bios upgrade w/out paying some $. I even tried jumpering to 1.5Gb/s data rate.
  • 99 Answers
You have to update your Bios./in your manual ,you can find on how to update your Bios.
Posted on Apr 02, 2008
SOURCE:
WD1600BEVT-60ZCT0 Not detecting
OK then. I assume the problem was solved by the procedure described in the last comment box - re-install USB disk drivers.
27.April.2014
Apr 15, 2014 | Western Digital WD1600BEVT-60ZCT0 - 160GB...
Upgraded HDD on D800 to 160GB drive. Worked fine for 2 wks. Shutdown and will not boot up. BIOS doesn't detect the drive. I can connect the drive to an external USB device and read all files on...
Could be an incorrect bios hard drive setting. Dell has a good customer service area. Did you use same type of drive SATA TO SATA? IDE to IDE? If you changed over there might be a setting to account for the difference.
Aug 25, 2017 | Dell Latitude D800 Notebook
Hello, Where could I find a driver for WD5000KS SATA? I am trying to upgrade my desktop PC to Win 7 but when installing it, the setup could not detect the SATA HDD and asked me to load the HDD driver. ...
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Jan 05, 2011 | Western Digital Caviar SE16 (WD5000KS)...
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
Sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Jun 10, 2009 | Biostar K8T80-A7 Motherboard
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
My sata hard hard drive is not detected in linux
Check in your BIOS settings that SATA drives can be seen as "ATA"
Install Linux, and then , after everithing went OK, change BIOS to SATA again.
Aug 04, 2008 | Computers & Internet
EliteGroup K8M800-M2 Motherboard Logo
240 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
