Question about Dell (E210882) Motherboard
Starting the computer up..
Hi! When I turn my Dell. it often blinks and the monitor doesn't turn on.What could be the problem?
  • SallieJohns
    SallieJohns May 11, 2010
    What kind of computer? Laptop/Desktop? Is the cable connected? Does the computer sound like it is starting up normally? (All disks and fans spinning as they should? Beeps? ) If you have speakers, can you hear if it tries to load windows?
    Problem Solver:
  • 17 Answers
If u have a dektop u have to chek ram and also chek if u plug out yr hdd cables seen that cable is roght place and also seen when u power on yr pc pc play some beep link thiss " teeeeet" if u seen then yr pc is ok problam is in my monitor..chek yr monitor cable chen monitor pin
thanks for using fixya.
jo_chinmay
Posted on Apr 02, 2008
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
My dell ultra sharp 1702 monitor blinks for quite awhile before starting up when I turn it on...?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board: www.lcdrepair.us
May 19, 2010 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
I have a Dell flatscreen monitor that will not turn on. The power light blinks blue slowly
Hi...there,
It's seems you got a busted backlight inverter. If you still under warranty send it back to Dell for repaired. Happy Holidays!
Dec 18, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Moniter won't turn on/power light blinks green
Yeah, I called Dell yesterday, and they said it was a problem that I could not fix myself. Whether that's true or not, I don't know, but my monitor was still under warranty, so they shipped me a replacement right away. I already got it this morning.
FYI: Their monitors carry a three year warranty.
Oct 28, 2008 | Dell E176FP 17" LCD Monitor
Dell E172FP, monitor blinks then goes blank or black
This is a known problem of the Invertor board.If you are technically able you can open the monitor and resolder transistors 2sc5707 as also all pins of 4 yellow invertor transistors that you can see near the backlight connectors.
Samir.
Please rate the solution and provide feedback
Sep 29, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor blinks out for 2 seconds
What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
May 29, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Nov 04, 2007 | Dell E173FP 17" LCD Monitor
Dell (E210882) Motherboard Logo
Alun Cox
