Question about GE Dishwashers
Ge dishwasher model gld5560l00ss --when you hit start nothing happens - if you hit start again , light on any selected switch begins to blink. have tried rebooting control that was suggested in owners manual by tripping breaker and then resetting after 30 seconds, ( this did not change anything). machine makes no noise but lights do come on.
  • Anonymous Apr 01, 2009
    I had the same problem, whih evntually turned into the unit not working at all. The touchpad control panel is dead. I did the "reboot" with the breaker. Looking for solutions before buying a new washer.
5 Suggested Answers
  • 5 Answers
SOURCE: dishwasher starts for seconds but, then shuts off
Check that water supply is available and that water inlet valve is operational. Filling unit is usually the first step of any wash program and dishwasher is shutting down because float valve is not actuated.
Posted on Jan 25, 2008
SOURCE: Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Posted on Dec 09, 2009
  • 189 Answers
SOURCE: MY DISHWASHER TRIPPED THE BREAKER AND WILL NOT COME BACK ON.
Hello- This series MDB7130 is involved in a recall. Check Maytag website for details. If affected, they will offer 75$ toward a new maytag.... or a free service call to 'retrofit' a new wiring harness. These units have caused a number of  fires so disconnect power until issue is resolved.- Let me know if this info helps. Thanks- Ed
Posted on Mar 12, 2010
mc1bean
  • 3053 Answers
SOURCE: GE profile dishwasher tripped breaker.
Hello, jjesup
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
When I hit the start button on my GE dishes washer the light in the front is blinking and it will not go on
This sometimes happens when there is a problem with the door latch system or switch. Your door may be closed but the control still thinks it is open. Check the door latch and switch alignment. GE had a problem with the doors dropping slightly about a year ago. the latch looks like a arrow head on top of the door center that pushes into the switch that is mounted on the dishwasher body. If the arrow head is slightly lower than the part on the body you will get the exact problem you are having. GE has hinge shims that they install to raise the door up slightly to fix the problem. Not sure your dishwasher is one of these without a model number.
Feb 28, 2015 | GE Dishwashers
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
My dishwasher lights are blinking but the unit will not run
push "Heavy Wash" "Heated Dry" "Heavy Wash" Heated Dry" "Drain Off"
Jan 26, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Green light flashing, won't turn on
A blinking light, and possibly no lights, with the door closed may indicate faulty door switches (very common on newer models). Depending on the model, the switches can be removed, cleaned and put back
Jun 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
377 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
