Question about Brother HL-2040 Laser Printer
PRINTER WILL NOT PRINT
The job is in the queue and the status says it's printing but it's not. It printed earlier just fine. It wont print form workd or quickbooks or the internet it's an Epson CX4800
    Genius:
  • 2,785 Answers
Reinstall your printer driver.if the problem is not solved then you scan your pc for viruse in safe mode by disabling the system restore.before scanning you have to update your anti-viruse software.
Posted on Apr 02, 2008
In Windows 7, items put in the print queue at home won't print when I get to the office.
I don't see how this can be done, because there are 2 different print queues in question. Not to mention the lag and buffer required by the printer. So when you disconnect communication the job hangs.
Besides the spooler at work my lie on a dedicated print server, especially if the printer is on a network and and not attached directly to you PC.
Feb 26, 2013 | Microsoft Windows 7 Professional for PC
My printer will not print still after I troubleshoot it and everything. I have a netbook laptop so I don't know why it's not printing. It says it's ready and everything
Problem Print job does not print; No Lexmark job status window Solution What you will see
  • The Windows print queue spools the print job.
  • The print queue icon appears in the systray or notification area.
  • The print queue icon disappears as if the print job has successfully been sent to the printer.
  • The print job disappears and does not print.
  • No Lexmark job status window appears to indicate a communication problem.
  • No other communication errors. This issue is most likely due to a corrupt device mode registry entry from another printer that was installed and used in the past.
Or
  • You do see the job status window and you do not see any alerts or communication errors, yet still nothing gets printed
What to do
A confirmed cause must be established before a resolution can be achieved.
To do this:
  1. download a diagnosis tool that will help determine the cause of the printing issue.
    IMPORTANT: Again, this tool is only to be used in cases where there is no communication error message from the Lexmark job status window and the job spools quickly through the Windows spooler, yet nothing prints.
  2. Select an easy-to-find Save location, such as your Windows Desktop.
  3. Double-click on the delserDevMode.exe file.
  4. Accept the License Agreement. After the file is executed, it saves devmode.txt to your root directory (e.g., C:\devmode.tx.
Aug 31, 2011 | Lexmark X2670 All-In-One Printer
Print jobs hang, won't finish, locks up printer
you must check print Queue, where's the printer one by one give access to print out. On there have status Queue, if any status Like "Stop,problem,etc" you must delete this Queue.
Mar 02, 2011 | HP Deskjet D4260 Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Wont print
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP DeskJet 712c InkJet Printer
Deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
Jul 01, 2009 | Dell Inkjet 720 Printer
How do I get the printer to print
Click on the printer icon at the bottom right of the screen. It should bring you to the print queue.
Make sure that the print queue has been released. Sometimes the queue will be in a "Hold" status.
You can also release each print job by clicking on the job and directing the queue to send the job to the printer.
Don
May 20, 2009 | Lexmark X6100 Flatbed Scanner
Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
Jul 28, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Lexmark c530dn wont print
disconnect this printer from your gigabit switch and try running it by itself. this printer should have its own on board memory. you may have uncompatible memories.
Apr 09, 2008 | Lexmark C530dn Laser Printer
Brother HL-2040 Laser Printer Logo
91 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
