HI,
Connect your adapter to the computer and install the drivers.
Then follow the instructions given below
On Windows XP :
Click on start >> go to control panel >> double click on network connections >> right click on wireless network connection and click on properties >> click on wireless networks >> check the box that says ”use windows to configure my wireless network settings” and click OK >> right click on wireless network connection again and click on view available wireless networks. If you see your network name then click on it and click connect >> enter password if configured and click OK.
Note : If you don’t see wireless network tab under wireless network connection properties then follow below steps.
Click on start >> click on run >> type services.msc and click OK >> scroll the right side window down to wireless zero configuration >> double click on it >> start up type should be set to automatic and service status should be started (In case if it is different then change the settings) Then follow the above mentioned steps to look for wireless network tab and follow further.
On Windows Vista :
click on start >> go to control panel >> double click on network and sharing center >> onto left, click on connect to a network. If you see your network name then click on it and get connected.
[Note : If you don’t see any network name and wireless switch is turned on then follow the below mentioned steps]
Click on start >> click on run >> type services.msc and click OK >> scroll the right side window down to WLAN Auto configuration >> double click on it >> start up type should be set to automatic and service status should be started (In case if it is different then change the settings). Then try to connect to your network again.
