Question about Asko Washing Machines
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
My usually reliable Cylinda 12000 Washing Machine stopped due to being unbalanced with a load of towels. Since then the drum spins during normal operations but not on the spin cycle, is there a reset mode to restore the spin cycle?
  • Anonymous Mar 21, 2014
    Can I order a belt immediately from NZ?
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
I have an Asea 9500 that will be 25 years old.It has been ana amazing machine.But now it will wash but not spin out.Instead of spinning the control dial just clicks and sticks. When I move the dial manually it will still not spin. Can anyone tell me if my old friend can be fixed in the UK ? Thank you.
Posted on Dec 27, 2009
Wixe167 just stopped running while spinning on last cycle
It stops spinning because the load is unbalanced. It will cycle over and over until the load is even then it will kick into a faster spin. Unbalanced loads could be due to too many items in the washer of a stabilizer problem in the hardware of the machine,
Oct 26, 2013 | Indesit Washing Machines
My machine stopped mid cycle and displays the letters dc, flashing. What is happening? thank you
I believe The dc code is due to an "unbalanced" load situation. Is this happening when it tries to spin? I know some washers have switches that sense this. Is this in the wash or spin cycle?
Sep 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
We have Asko WMachine Cylinda 12000 and it won't spin out the water. Machine working fine but won't spin or drain water out.
Welcome to FixYa.
Based on your description, " Machine working fine but won\'t spin or drain water out " it could be just a clogged pump insert/filter.
It's not very difficult to check though, you'll first need to remove the panel beneath the door...it should just pull forward and off.
**Unplug the washer before servicing the unit though...safety first** You may also need to have a wet-dry shop vacuum or plenty of towels as there will be quite a bit of water present.
Carefully remove the filter from the pump by turning it ( slowly to allow water out gradual )...the issue with these Asko pump inserts/filters is they can get so clogged up they are stuck and difficult to remove...
i.e.
these can become clogged with items such as coins, hair-pins etc. that can actually damage the part. Once the filter is removed check the pump thoroughly as well as the hoses to rule out any other possible blockage.
Unfortunately once they are clogged to an extreme degree removing the filter by normal means becomes difficult or impossible without breaking it as I alluded to.
The image I attached above is an example of a pump I had to remove and disassemble to clean it out so the filter could be removed/unscrewed, hence the need for the "worm-gear" clamps had to be used to replace the original "one-time" clamps.
If you indeed break this part during your attempts to remove it, a replacement is available, Asko original part # 88 010 69 and available at on-line retailer "repairclinic.com" for about $25-$30USD.
i.e.
Let me know how you make out or if you require further assistance. Ultimately the drain pump itself could be faulty, but I'd certainly check for obstructions first.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Dec 26, 2010 | Asko Washing Machines
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
What does unb at end of wasn after it says end??
unbalanced - means it didnt spin properly due to clothes being unbalanced. Its supposed to stop the machine damaging itself - but its just a pain. Need to fill the machine with a full load to avoid this. Dont suppose your machine's a Haier??
Jan 03, 2009 | Washing Machines
Roper washing machine- unbalanced spin - rocking agitator
I usually stand in front of the washer and take the plams of my hands and forcefully provide a force with the heel of my hands on the side front corners and the lip comes up
Another option is to pull the washer out and remove 2 clips (usually requires quarter inch nut driver to allow the top to come up
This should allow you to get the top off to see if a spring has broken or slipped off
GOOD LUCK!
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Need a manual for a asea cylinda 12000 washing machine can you help please
Dear sooty388,
Have you found a manual for you Asea?
I need one too.
If you would, please reply at this email address.
Kind Regards,
Dhugal Bissett.
Melbourne.
Apr 14, 2008 | Zanussi FJS1225W Front Load Washer
Unbalanced load cabrio top loader
being un-level could certainly cause it im currently working on this problem for another customer on this site while i haven't had hands on with this model yet i just finished reading the service manuel on it its kind of an amazing concept in washers if either one of you are on line reply to this message hold my rating for now as i need to ask some questions
Dec 23, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
1,529 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
